12-17-2015, 03:12 PM | #1 |
Help on removing the radiator shell
Greetings guys.
I am having a small problem trying to remove the radiator shell on my barn find 29 Tudor Sedan. I almost feels like the shell is soldered to the radiator. Is this possible, or is there a trick to removing it? I have followed the instructions in my copy of Les Andrews’s mechanics handbook up to the point where is says “Slide the radiator shell straight up and off the radiator”. In my case it will not budge an inch up. Thanks in advance for any advice |
12-17-2015, 03:17 PM | #2 |
Re: Help on removing the radiator shell
Is it loose at the sides and just stuck at the top??
Bob |
12-17-2015, 03:35 PM | #3 |
Yes Bob, Both sides are loose, and I can rock the shell fore and aft, side to side, just not up.
12-17-2015, 03:42 PM | #4 |
Could be rusted to the tabs where it was bolted/screwed together?
A little prying with puddy knife to separate it? I type too slow :-( Last edited by Big hammer; 12-17-2015 at 03:44 PM. Reason: Addition |
12-17-2015, 04:31 PM | #5 | |
Try rocking it upwards using some heavy oil or grease. Larry
Good enough.. Isn't. |
12-17-2015, 07:24 PM | #6 |
12-17-2015, 08:05 PM | #7 |
I have seen the radiator shell wear a groove in the radiator neck. That may be something to look for.
Bob |
12-17-2015, 08:17 PM | #8 |
Uhhh,......is the cap off?
12-17-2015, 08:59 PM | #9 |
12-17-2015, 09:21 PM | #10 |
That always works, but the results are mixed.
12-17-2015, 09:23 PM | #11 |
Bob has a good point. I have seen that groove.
Drop the shell back down and try to file off the ridge with a small smooth file, like a "point" file. A little lube; two hands and some wiggling will work. Larry
12-17-2015, 09:31 PM | #12 |
"A little lube; two hands and some wiggling will work."
Don't say it, Horton. Leave it alone...
12-17-2015, 09:46 PM | #13 | |
One's enough.. Larry
12-17-2015, 09:55 PM | #14 |
should also remember after 80 years its very much possible someones soldered it down.
when you rock it side to side can you see the shell rock side to side on the neck?
1929 Model AA - Need long splash aprons! |
12-17-2015, 10:01 PM | #15 | |
Larry
12-18-2015, 07:35 AM | #16 |
repro '29 radiators, in my observation, do not have the identical neck on them as did the original. the original had some slop factored into its design that allows the shell to wiggle a little, making it easier to attach the brackets.
12-18-2015, 08:38 PM | #17 |
The repros I have seen are '28s. The emboss around the crank hole is'28 and the holes for the headlight conduits are too small. Also, I haven't seen one that is nickel plated or that has a correct front-on profile. Good originals are rare, but try to find one if you can. Sorry, this is off topic. Glad the OP got his problem solved.
12-18-2015, 11:37 PM | #18 |
