Old 06-18-2011, 07:03 PM   #1
brentom
Default My 49 mercury water pump
Will 51 merc motor water pumps work on the 49? I have a donor 51 with the original flathead in tack and want to remove the water pumps and send to get rebuild then install in my 49 mercury and not have any downtime.
thanks in advance,
tom
brentom is offline   Reply With Quote
Old 06-18-2011, 07:17 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: My 49 mercury water pump
No, the pulleys on '50 and '51 are narrow belt. (other than that the pumps are vertually the same)
You could transfer the whole '51 setup, crank pulley, fan and generator etc.
Old 06-20-2011, 04:50 PM   #3
blown49
blown49's Avatar
I believe the foot mount is also different on the '49
Jim
Visit my Blown '49 Merc website @ http://www.blown49.com
blown49 is offline   Reply With Quote
Old 06-20-2011, 05:22 PM   #4
rotorwrench
rotorwrench's Avatar
Early 49 Merc pumps were oiler type with bushings plus the wide sheeve as already mentioned. Later pumps will work on a 49 if you put the wide belt sheeves on. FoMoCo made a coversion kit to use the biscuit type mounts with the spacer adapters. The old block shaped mounts are more available now than they were back in the 60s.
Kerby
Old 10-01-2013, 01:44 PM   #5
Bobs1953
I am also looking for 49 Merc water pumps any info where I can buy sum or have mine rebuilt ? Thank for any info
Bobs1953 is offline   Reply With Quote
Old 10-01-2013, 01:50 PM   #6
Tim Ayers
Jim
Yes, the foot on a '49 Merc pump is different than the others. I was helping my buddy clean out some parts and was able to see them side-by-side. Clearly different and I think one year only.
Old 10-01-2013, 01:51 PM   #7
Tim Ayers
Are you going to Hershey? If so, my buddy will have two sets there for sale. Pretty cheap I may add.
Old 10-01-2013, 01:58 PM   #8
Mr. Will
Mr. Will's Avatar
I have used these guys on several occasions and their work is top notch, very reasonable and, a quick turnaround. Call Tony and he will give you a run down on what they do. http://user.cavenet.com/tmac1/
Mr. Will is offline   Reply With Quote
Old 10-01-2013, 01:58 PM   #9
my4dv8
I think the 49 merc pump mount is about 1" higher than later ones and also 8ba.
my4dv8 is offline   Reply With Quote
Old 10-01-2013, 03:10 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
49'-51' Mercury car pump bodies all mount the same way using the same motor mounts
Old 10-01-2013, 04:08 PM   #11
Vic Piano
Vic Piano's Avatar
Give Skip Haney a call to have your water pumps rebuilt. His phone # is: 941-505-9085.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-01-2013, 04:12 PM   #12
billwill
Try shoeboxford ,com
billwill is offline   Reply With Quote
Old 10-03-2013, 11:47 AM   #13
19Fordy
19Fordy's Avatar
Can someone please post a photo of a 1949 and a 1951 Mercury water pump.
I always thought they were the same except for the pulleys. Thanks. Jim
Old 10-03-2013, 12:29 PM   #14
rotorwrench
The only major difference in the casting has to do with the type of bearing arrangement. The early 49 pumps have a spring loaded oiler cup and uses a bushing/bearing combo inside the housing. The later design has the sealed double row bearing/shaft assembly to fit. The sheaves were wide belt in 49 with single belt for both pumps then went to narrow double offset belt set up in 50. The tall square rubber block front mount was replaced with the biscuit type mounts that had to have an adapter to make up the hight dimension difference & alignment difference. The front frame cross member is different for the early 49 set up. The later 49/51 biscuit type mount with the big hole is located slightly offset from the single smaller bolt hole of the earlier 49 mount due to the size of the hole that was required to make the biscuit type work.
As far as I'm aware, there is no dimensional difference externally on the housing castings.
Old 10-03-2013, 12:40 PM   #15
51 MERC-CT
51 MERC-CT's Avatar
As stated the major difference is the pulleys with improvements to the bearings. And some of the late 51's had holes in the impellers supposedly to reduce cavitation.
Old 10-03-2013, 06:43 PM   #16
Randy
Randy's Avatar
These have narrow pulleys and an 0CM part #, I guess they are '50-'51 Merc?
Randy is offline   Reply With Quote
Old 10-03-2013, 06:52 PM   #17
rotorwrench
If the 8CM pump has the hole for the oiler cup then it is an early 49 type. The OCM pumps were used through 1951 and had the sealed bearing/shaft assembly. Previous rebuilders may have converted the 8CM pump to the later configuration. Sometimes it is hard to tell the 8 from the 0 in the part number unless you beed blast them.
