Old 09-16-2018, 08:14 PM   #1
Ford Acar
Smile Wind Wing glass
Hi all,
Could someone please advise the correct thickness of glass/perspex for wind wings? The instructions that came with my Vintique kit are not very specific.
Thanks.
Ford Acar is offline   Reply With Quote
Old 09-16-2018, 08:53 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Wind Wing glass
The clamps are adjustable and will take a range of thicknesses. I think the glass is usually about 1/4" thick. The thinner the better because glass is heavy and the clamps crap. Use every trick you can imagine to prevent your glass ending up in a million pieces on the road.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-16-2018, 08:59 PM   #3
J Franklin
J Franklin's Avatar
When I need a good sealant/adhesive for glass, I like clear silicon caulk/sealant. I learned this working in an alarm business. Lasts many, many years in this application.
Old 09-17-2018, 02:55 PM   #4
woofa.express
woofa.express's Avatar
Yes, I lost 2 glasses on the road side. For the rubber I substituted two sided sticky tape, fairly thick stuff, ensured I had the glass correctly in place and clamped. Then used a blade to cut off the excess from around the clamps and bingo.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 09-23-2018, 06:03 AM   #5
Ford Acar
Thanks for your input. I decided on 6mm perspex which is fractionally under 1/4 inch and much lighter. Used silicone as the adhesive and all looks very secure.
