Old 03-15-2020, 09:33 AM   #1
Topher5150
Default Flat u-bolts
I don't know if this is the right place to ask this, but I am lowering the front of my 47 coupe via the Speedways lowered crossmember. The u-bolts that originally came with were flat on top, but don't fit this crossmember because they taper. I'm having some clearance issues with my 351, and was wondering if there were any flat top u-bolts like this with a 2.75" ID without a taper like this???
Topher5150 is offline   Reply With Quote
Old 03-15-2020, 09:38 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Flat u-bolts
Have a spring shop make what you want..................
Paul in CT
Old 03-15-2020, 09:54 AM   #3
JSeery
JSeery's Avatar
Do a search online for square-U bolts and see if any look like they will work. They come in standard sizes. If you can't find a stand size that will work, you could heat up and flatten out a U-bolt or have one custom made.
Old 03-15-2020, 10:10 AM   #4
Topher5150
I had a set o u-bolts made at a spring shop, but they only use round stock.
Old 03-15-2020, 10:27 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
An acetylene rig and a big, friggen' hammer can turn that "roundness" into flatness with a smidge of finessing, if ya hold your tongue just right. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-15-2020, 11:09 AM   #6
38bill
38bill's Avatar
Taper? Do you mean that the opening between the threaded ends is pinched together? Or is the flat too narrow for the cross member?
38bill is offline   Reply With Quote
Old 03-16-2020, 10:06 AM   #7
Topher5150
they aren't quite perpendicular....so at the bottom where it's threaded the distance is greater then at the top.
Old 03-16-2020, 12:11 PM   #8
JSeery
JSeery's Avatar
You can't bend them to fit?
Old 03-16-2020, 12:54 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Sounds like they're too narrow at the top, so that ain't gonna work. DD
T5 W/TORQUE TUBE
Old 03-16-2020, 01:21 PM   #10
JSeery
JSeery's Avatar
Would depend on how much of a clearance issue there is, but if it is not much I would construct a quick form and drive the bolts over it to get the required fit. If a small amount it should be able to be cold hammered. If more than that, a little heat should do it.
Old 03-16-2020, 01:41 PM   #11
Krylon32
Try Pete & Jake's. They offer u bolts made for repro cross members. I used the CE reproduction cross member in a number of 35-40 repro chassis and got my front clamps from them.
Krylon32 is offline   Reply With Quote
Thread Tools
Display Modes
