11-23-2019, 06:06 PM | #1 |
41 Ford shift lever removal
I have an old steering column that I'm trying to ship. I saw there was a pin at the base of the shifter I tried popping it out with a punch but that didn't seem to work. Any suggestions???
11-23-2019, 06:17 PM | #2 |
Re: 41 Ford shift lever removal
What looks like a pin isn't in the usual sense.' It is 2 small cylinders with a small spring between them. Take 2 small nails and push on each one at the same time and the shift lever should pull out.
11-24-2019, 11:46 AM | #3 |
