Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 08-12-2019, 04:43 PM   #1
Aeronca7AC
Default '28 Model A cranks but won't start.
Hello. Just bought a '28 Roadster. Worked great for a few days. Did the normal routine maintenance including all fluids, timing, points, plugs, etc. Now she has no lights, horn, etc. but will crank away.Would sure appreciated suggestions. Own a test light but don't know much about electrical. Any suggestions appreciated! Thanks! Dave
Aeronca7AC is offline   Reply With Quote
Old 08-12-2019, 08:57 PM   #2
Charlie Stephens
Default Re: '28 Model A cranks but won't start.
Does it have a fuze? Power to the starter doesn't go though the fuze.
Also you posted in a forum intended for questions "To The Editors". Leave it here but also post here: https://www.fordbarn.com/forum/forumdisplay.php?f=3
Welcome to fordbarn.
Charlie Stephens
Old 12-07-2019, 06:32 PM   #3
Rochesterguy
If it has a fuse replace it or clean contact ends with emery paper.
Rochesterguy is offline   Reply With Quote
