09-08-2019, 09:44 PM | #1 |
L-4 Kingston carburetor seat
I had a tough time removing this seat and probably should run a tap in there to clean up the threads. I thought there would be a new seat in the rebuild kit I have but it ended up needing to be ordered separately so I don't have it yet. Anybody happen to know the diameter and thread spacing on this? |
09-09-2019, 02:34 AM | #2 |
Re: L-4 Kingston carburetor seat
Have you tried Ecklers ? They seem to have a varied selection of Model T parts
Tel 877-815-5799 |
09-09-2019, 11:09 PM | #3 |
Where are you located?. When you get one, get the original style not the two ball type.
I know the voices aren't real but damn they have some good ideas! |
09-10-2019, 08:14 AM | #4 |
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
09-11-2019, 08:20 PM | #5 |
I had the replacement ordered already, it looks like the one pictured and identical to the mangled one that came out, so it should be original. I wonder if the "two ball" type was the part in the kit I didn't recognize.
The problem is just that the threads in the carburetor were slightly damaged, so I need to run a tap or at least a hard bolt of the right size in there to clean it up so I don't damage the threads on the new seat. The new part arrived so I'll just take the seat into Lowes and use the bolt sizer to figure out what I need. Does that copper washer go under the bottom of the seat? Don't recall that coming out with the old one, I'll have to look again. |
09-13-2019, 09:00 AM | #6 |
10-02-2019, 09:51 PM | #7 |
For future reference, a 3/8 - 16 tap worked to repair the seat threads.
Since the carb had a lot of pitting and surface rust, after it came out of the dip bucket I hit it with a wire dremel brush. Then after taping off the openings, I coated it with POR15 fuel tank sealer. I've had good results with regular POR15 so we'll see how this works out. |
