Old 01-18-2023, 06:10 PM   #1
cjc56
Default Upper control arm placement question
On a 1958 Ranchero are the upper control arms centered on the control arm shaft or are they off set on the shaft. This 1958 ranchero has screw in bushings
cjc56 is offline   Reply With Quote
Old 01-20-2023, 08:50 AM   #2
bobss396
bobss396's Avatar
Default Re: Upper control arm placement question
I have a '59 and they are centered. The bushings have a coarse thread where they go onto the shaft and a fine thread where they go into the control arm. They are a little tricky to install.
bobss396 is offline   Reply With Quote
Old 01-20-2023, 09:28 AM   #3
cjc56
Thanks for the reply. I wish the manual was a little clearer. And yes they are tricky getting them in while keeping it centered on the shaft. Thanks again.
Old 01-25-2023, 09:18 AM   #4
bobss396
bobss396's Avatar
The last ones I did were on my car, the previous was while fixing cars. I did a '64 Ford around 1979. You need to take pains to keep the shaft and arm centered. I good scribed line does the trick, or take side to side measurements.
The hardest part is dealing with 2 different threads at a time and not strip out the fine thread in the arm.
