10-25-2022, 03:58 PM | #1 |
Oil sending unit for a 1935 ford
I am having a difficult time locating the oil sending unit for my 1935 ford. I have contacted several vendors and all indicate that they do not have this item. Can anyone tell where I can purchase this item. Thanks for your help.
10-25-2022, 04:26 PM | #2 |
Re: Oil sending unit for a 1935 ford
There is a used 35-42 Ford 50lb sender on Ebay right now for$50. Two NOS 50lb senders sold for $100 each if that tells you anything.
10-25-2022, 09:21 PM | #3 |
Good 50# oil pressure sending units are difficult to find. There should be some old posts in the archives here on that mention a 50# sending unit used in production and service of Mopar vehicles. If you are not concerned about authenticity, this may be a good option to persue.
10-26-2022, 12:33 AM | #4 |
Here is a replacement:
https://www.kaiserwillys.com/oil-pre...wagon-jeepster |
10-26-2022, 10:27 AM | #5 | |
10-26-2022, 02:44 PM | #6 |
10-26-2022, 02:56 PM | #7 |
You’ll need this to go with the Kaiser unit as it doesn’t fit the block.
Tim Carlig |
11-01-2022, 08:45 AM | #8 |
I have acquired an 80lbs oil sending unit for my 1935 ford. Since I could not locate a 50lbs sending unit I am wondering whether the 80lbs unit will work. The oil gauge only goes up to 50lbs and my concern is that the 80lbs unit will peg the gauge and give me no useful information relative to oil pressure. I welcome your comments. Thanks for your help.
11-01-2022, 08:59 AM | #9 |
Look at post #4.Its a link to a 50 lb sender,then post #7 for the adapter.Your 80 lb sender will not work properly with a 50 lb gauge.
11-01-2022, 09:35 AM | #10 |
I have 50 pound sending units
11-01-2022, 11:05 AM | #11 |
Do the sending units work and if so what is your asking price?
11-01-2022, 11:25 AM | #12 |
I just got a used 50lb sender from Fred (barnfind08) and it works great.
11-01-2022, 12:38 PM | #13 |
Nice used $35.00 plus $8.00 postage
11-01-2022, 01:41 PM | #14 |
You's guys are 'MISSING THE BOAT' if you're not checking with "barnfinf08" (Fred Wilner) first for those obscure parts needs. Fred Wilner - (barnfind08") SOUTHSIDE OBSOLETE 7136 200th St E. Faribault, MN 55021 (507) 332-6789 Direct PM to "barnfind08"....Click the Link BELOW https://www.fordbarn.com/forum/priva...do=newpm&u=104 . |
11-01-2022, 11:47 PM | #15 | |
