08-07-2022, 01:14 PM | #1 |
1/2 - 20 repair fitting
I need a source or pt # for the repair fittings that I find in core carbs that
find their way into my stash. The male end has 1/2-20 threads and seals with a gasket against the inlet . The female end accepts 1/4 tube , ferrule and 1/2-20 Ford nut. I use these fittings to salvage 94 air horns where the ferrule seat is no longer concentric enough to be leak proof. I'm running low ! Charlie ny |
08-08-2022, 05:46 AM | #2 |
Re: 1/2 - 20 repair fitting
Charlie, is this what you need? I’m not sure if the inlet side of this one is made for a Fordnut or flared line. Worth a look.
https://www.carburetor-parts.com/Bra...80_p_2408.html Joe |
08-08-2022, 08:17 AM | #3 |
HB,
I'll give mike a jingle and see if he has them for Ford nut....the inlet on the one in photo is for flared. Thanks, Charlie |
08-08-2022, 11:08 AM | #4 |
Deleted
08-08-2022, 11:21 AM | #5 |
08-08-2022, 12:29 PM | #6 |
Don't go too far...do you have any ?.....Mike's came up dry. Charlie ny |
08-08-2022, 01:19 PM | #7 |
I am thinking that Max had (or has) this sort of stuff. Try Max?
Post #2 seems to have what I think you are asking. |
08-08-2022, 02:41 PM | #8 |
Weatherhead 59X4 look them up on the internet.
08-08-2022, 03:26 PM | #9 |
1/2-20x8an fuel inlet adapter fitting, quadrajet parts.com
kurt |
08-08-2022, 08:24 PM | #10 |
https://www.vintageford.com/global_s...0507&Category=
FUEL LINE BRASS FITTING WITH FERRULE 1/2 INCH HEAD 1/2-20 FUEL LINE BRASS FITTING LARGER 9/16 INCH HEAD 1/2-20unf |
08-08-2022, 08:25 PM | #11 |
For 1/4" line...
08-09-2022, 06:50 PM | #12 |
Charlie I deleted my comment as I had a solution that had apparently dried up… I have none. Check with James at Gotham auto parts.
08-09-2022, 08:11 PM | #13 |
Same as a model A fuel line. Brattons antique auto has them...or did
08-09-2022, 08:47 PM | #14 | |
Charlie isn’t looking for the fittings shown they are readily available, heck we even have made them for the model a vendors. |
08-09-2022, 08:49 PM | #15 |
Charlie I can get them but they are for a flared line not a ferulle
08-10-2022, 06:57 AM | #16 |
Michael....thanks.
Charlie ny |
08-10-2022, 08:12 AM | #17 |
What would it take to take one of the available flair fittings and remachine the seat to take a 1/4 pipe ferrule?
08-10-2022, 08:23 AM | #18 |
08-10-2022, 04:39 PM | #19 |
Weatherhead went to Eaton. They may have manufactured stuff like that back in the day. A person would have to an old catalog to find out. If there is a part number then a person may be able to find them.
08-10-2022, 06:51 PM | #20 |
Mart,
I'm working on it now...to keep 100% concentricity between the seat and threads is more than plunging a countersink into the flare contour. Charlie ny |
