Old 07-20-2022, 07:26 PM   #1
53Customline
53Customline's Avatar
Default Flushing a steering box
What is best to flush a steering box with diesel or clear kerosene?
Oil drained & off car so I am able shake & flush several times to hopefully loosen up sludge.
Car is 1953 Customline
Don’t want to disassemble unless necessary
Thanks for your advice
Randy in Raleigh
53Customline is offline   Reply With Quote
Old 07-20-2022, 10:06 PM   #2
fordor41
fordor41's Avatar
Default Re: Flushing a steering box
I would think diesel or kero would work. at least you'll have some film left on the inside parts in case you rotate the input shaft to get it clean
fordor41 is offline   Reply With Quote
Old 07-21-2022, 05:48 AM   #3
highbeams
highbeams's Avatar
Why would you flush a steering box? The 'sludge' is obviously oil remnant; you have seen sludge in the steering box? . The steering box is not a combustion chamber. Oil change in a combustion chamber is necessary; but in a steering box with subtle moving parts?
Thanks in advance for your reply.
highbeams is offline   Reply With Quote
Old 07-21-2022, 08:39 PM   #4
53Customline
Fordor41 Thanks for your replay.
I agreed both will work, hoping someone had experienced this and steer me clear if damages might occur.
The petroleum additive in both products will hopefully eat away the sludge in the corners when agitation applied & mix well enough when refilled with oil. After through draining.
Randy
Steering box sat garaged for nearly 50 years.
Old 07-21-2022, 08:50 PM   #5
53Customline
Highbeams
See my previous response regarding how long will the box has been sitting.
Currently box is draining & oil is thick & filty black. I am figuring sludge is same as rear axle was when it was cleaned out
If there is something I am missing please let me know.
This car is important to me.
I move slow but t study hard & questions
Answers, advice & stop don’t do that are all welcome
Thanks
Randy in Raleigh
Old 07-22-2022, 04:09 PM   #6
Pete
Pete's Avatar
That particular box can NOT be cleaned properly without disassembly.
Old 07-22-2022, 07:38 PM   #7
highbeams
highbeams's Avatar
Originally Posted by 53Customline View Post
Highbeams
Thanks
Randy in Raleigh
Thank you, Randy.
I apologize; my ignorance.
- highbeams.
Old 07-22-2022, 09:38 PM   #8
Clem Clement
Clem Clement's Avatar
I thought I would fill the box with kerosene jack
up the front end and exercise the box. Then use air pressure to force the mess out of the box 2/3times and fill with corn he3ad grease.
Old 07-23-2022, 09:06 PM   #9
53Customline
Thanks all for the replies.
Will post the results.
Hope the seals hold up.
Randy
Old 07-24-2022, 07:41 PM   #10
highbeams
highbeams's Avatar
got sludge?
https://www.machinerylubrication.com.../gear-oil-life
