Old 03-05-2021, 11:44 AM   #1
STAN WHITE
Default 34 ford front fender tie
What is the proper method for installing the front fender tie? Thanks. Stan
STAN WHITE is offline   Reply With Quote
Old 03-05-2021, 01:42 PM   #2
DavidG
DavidG's Avatar
Default Re: 34 ford front fender tie
Originally it was likely first attached to the bottom of the grille with the long front fender welting centered between it and the grille (held in place with a binding head screw) and then clamped to the front fenders once they were installed.
Old 03-05-2021, 05:11 PM   #3
mercman from oz
mercman from oz's Avatar
Very helpful picture of the underside of the 1934 Fords.
Old 03-05-2021, 07:12 PM   #4
DavidG
DavidG's Avatar
Not obvious from the photo, but it is a extremely low-mileage '33 in this instance. Note the scalloped leading edge of the bottom of the front cross member The details pertaining to the question posed are the same for '34.
