07-09-2018, 09:09 PM | #1 |
Engine removal question
In reading the engine removal instructions in the Les Andrews book, he says to remove the intake and exhaust manifolds, the distributor, oil filler pipe, etc.
If I'm just doing an engine swap, can those items be left on the engine during removal and installation? It seems to me they won't be in the way of anything if the radiator and headlight bar are removed. |
07-09-2018, 09:23 PM | #2 |
Re: Engine removal question
You can leave that stuff on. I would remove the distributor at a minimum though.
Dave / Lincoln Nebraska |
07-09-2018, 10:34 PM | #3 |
I would also make sure the carb is removed also
Fred Kroon 1929 Std Coupe 1929 Huckster |
07-10-2018, 08:10 AM | #4 |
when I pull / install motors, with or without transmission, I don't remove the headlight bar, as it's a pain to get off / on.
but you need a hoist / chain-fall that can lift vertically not a classic arm based engine hoist. a Gantry Crane works well. |
07-10-2018, 09:24 AM | #5 |
I,m OLD, I've seen a Model A motor removed with a CHAIN, a LONG pole, 2 STRONG Men & a BOY!!!
Bill Ihelped
07-10-2018, 01:41 PM | #6 |
07-10-2018, 01:50 PM | #7 |
07-10-2018, 02:06 PM | #8 |
That's the way my Dad & I did it, except that there was only one man and me as a teenager.
07-10-2018, 06:14 PM | #9 |
Yep, remember pulling a 4 cyl. engine out of a 1958 MG using a 2x4, rope and another guy as crazy as I was. That was about 55 years ago. Nowadays I use the same method to remove the engine off an old lawnmower.
Is this what is called an "acquired skill", or??? Last edited by chap52; 07-10-2018 at 06:15 PM. Reason: spell'n |
07-10-2018, 06:37 PM | #10 |
I decided to remove the headlight bar, the idea of lifting the engine high enough to go over it didn't appeal to me, getting the mounting bolts out thru the fender brackets was a PIA, however the worst part was undoing the headlight wires which the previous owner had connected with crimped wire splices, had no choice but to cut the wires. Waiting for help to lift the hood off next. Most everything else is disconnected and out of the way.
I'm pulling the engine only, not the tranny. Will keep you posted, thanks for the advice. |
07-11-2018, 04:01 AM | #11 |
Good idea to remove the throttle linkage from rear of engine so that it does not get all bent up as they often do.
Many times it takes hours of messing around to get the linkage to work again! Often the two 0.010 thick shims from upper flywheel cover bolts get lost in the process so good idea to check that they do not drop off and get lost. Last edited by Benson; 07-11-2018 at 03:48 PM. |
07-11-2018, 07:49 AM | #12 |
Once I freed up the hinge pins, I removed the hood, in sections, to prevent damage. Then I replaced the hinge pins with WOOD Dowels, soaked in Linseed Oil. Linseed Oil comes from FLAX SEEDS. (NOT good for cookin' FOODS!)
Bill Tricky
07-11-2018, 11:51 AM | #13 |
To remove the hood you can remove the rear mount, the fold both sides up and rest them on the cowl. Move to stand in between the frame rails and grab both hood handles and lift it free. Slowly rotate yourself and remember to step over the front bumper and lower it onto a piece of carpet or cardboard. Well it works for me..........
07-11-2018, 05:43 PM | #14 |
07-11-2018, 06:21 PM | #15 | |
