05-29-2018, 11:26 AM | #1 |
Coolant leaking from manifold stud
I just filled the engine/chassis that has been sitting for 30 years with coolant and ran the engine for several minutes. After cooldown I notice that there is a small amount of coolant that appears to be leaking from the 3rd manifold stud (toward the firewall). It's a very small leak, just a drop or two along the top of the valve cover. It looks like this stud may have been redrilled at sometime as it's a bit crooked. Is this something to be concerned about?
05-29-2018, 10:45 PM | #2 |
Re: Coolant leaking from manifold stud
I would drain the coolant, remove the stud and seal the threads. Any leak is something to be concerned with.
05-30-2018, 07:42 PM | #3 |
Thanks Tom,
I should have asked if these studs normally extend into the water jacket or if something else might be wrong, like a crack? |
05-31-2018, 07:13 AM | #4 |
You will have to deal with it Tom's way eventually. Your call. Chap |
