05-11-2018, 09:31 AM | #1 |
rear axle/hub questions
I put new hubs and drums (cast iron) on the rear (they were properly mated together, or so I was told). When I tightened down the axle nuts one side was about a quarter inch further up the axle then the other side. I assume this is due to the amount of wear on the existing axles (the drum/hubs were installed dry with proper fitting keys).
Also how can you tell when there is so much wear in the axle/hub to use a shim? Is it when the drum starts to rub on the backing plate after tightening? |
05-11-2018, 09:38 AM | #2 |
Re: rear axle/hub questions
yes, they will rub. if the hub goes on the far just add a shim.
05-11-2018, 01:03 PM | #3 |
If you need a thicker shim, make one. It is not good to stack shims. I have seen cars that had 3, two is bad enough but 3? Make sure the backing plates are not bent also.
05-11-2018, 03:45 PM | #4 |
Our drivers side rear hub took an extra washer that the rear passenger side didn’t need.
Make sure hub is not rubbing on backing plate. Torque to 100 psi. |
05-11-2018, 08:15 PM | #5 |
Okay, thanks.
05-11-2018, 08:19 PM | #6 |
05-12-2018, 09:40 AM | #7 | |
05-12-2018, 10:40 AM | #8 |
Thread Tools | |
Display Modes | |
