04-09-2021, 08:58 AM | #1 |
Shackle pin, heads up
Recently bought and installed a set of 51A-5713 rear shackle pins in the '40. These were Ford script, USA. They measured anywhere from .753 to .756 OD, and I believe the variance in OD was what appeared to be galvanize plating. It was so thick on the .756 ones that the nut would not thread on the shackle stud. I have not seen galvanizing on any of the shackle pins I have used before, so this was new to me. The lesson learned here was check the OD on each one, and if needed, take a little of the galvanize off, and by all means, before you install them, run a nut on the shackle threads. It was tough to run a die over the threads once they were in the spring perch.
04-09-2021, 09:34 AM | #2 |
Re: Shackle pin, heads up
Don't breathe that shit in.
04-09-2021, 09:50 AM | #3 | |
Ford used different metals for the casing on these pins. Terne plated steel, I believe, was the most common.
04-09-2021, 02:25 PM | #4 |
Unusual to see plating of any sort on the shackles
04-09-2021, 02:36 PM | #5 |
Terry, like you, I'd never seen them plated.
04-09-2021, 11:01 PM | #6 |
04-10-2021, 06:34 PM | #7 |
I have never seen any shackles plated either. They were stamped Ford USA, and came from 3rd gen, and I was happy to get the original type. I would have posted a picture, but they were already installed when i thought of it.
