11-19-2020, 11:11 AM | #1 |
15" Rims
My brother is looking for a useable set (4 or 5) of stock 15" rims for his '46 coupe in the Reno Nevada area. Speedway has rims with 7" bead width, but at $120 each, beyond the budget. Nothing on Ebay or Third Gen. Any suggestions where to look.
11-19-2020, 11:32 AM | #2 |
Re: 15" Rims
I had my last set custom made, don't remember the price, but it wasn't that bad. And a lot of that was the shipping. There is a shop in LA I think, I could look it up if your interested.
11-19-2020, 01:51 PM | #3 |
Re: 15" Rims
11-20-2020, 02:52 PM | #4 |
Re: 15" Rims
Well, little more difficult to sort out than I thought! My last purchase was for 2 custom made rims (different offset and width than normal), but had them powder coated and the shipping is in there, so? $376 for the pair, that's $188 each. But again, not sure how much was powder coat and how much was the rims.
Wheelsmith http://thewheelsmith.net/wheel-catal...vintage-wheels |
11-19-2020, 12:12 PM | #5 |
Re: 15" Rims
A factor here is whether he wants to run stock hubcaps or not. If not, wheels should be easy to find, from '49-'51 Mercs and a variety of Ford pickups. If so, he is limited to the venerable '48 Merc wheel, a much smaller selection of Ford pickups, or custom made.
11-19-2020, 12:36 PM | #6 |
Re: 15" Rims
11-19-2020, 03:04 PM | #7 |
Re: 15" Rims
The pickup 15" wheel for the stock style hub caps are 1956 to 66 and still a lot of them still around for $50 each and less.
I have found them in good shape in junkyards with a junk tire and if you offer to take it with the junk tire the price gets cheaper |
11-19-2020, 03:58 PM | #8 |
Re: 15" Rims
X2. There has to be a junk yard in or near Reno/Carson City that has some older Ford pickups.
11-19-2020, 04:22 PM | #9 |
Re: 15" Rims
Agreed with many of the above comments. For example, I am still storing two 15" wheels that came on a 64 pickup (that I bought new). They take the early hubcap. So, I think there ought to be wheels available in your area. I'd offer mine for free, if we weren't separated by a few thousand miles.
11-19-2020, 04:27 PM | #10 | |
Re: 15" Rims
11-19-2020, 05:46 PM | #11 |
Re: 15" Rims
He wants 7-inches between the beads! Ford didn't make 7-inchers for the early caps. DD |
11-19-2020, 05:53 PM | #12 |
Re: 15" Rims
He just stated thats what speedway had for $120 but out of his budget. Didnt say they had to be 7" . Sounds more like he would settle for something cheaper.
11-19-2020, 05:58 PM | #13 |
Re: 15" Rims
You're ARE correct, Skids! So, we both know that 5-1/2" wide pick-up wheels are all over the place through '66, for the early caps. DD
11-19-2020, 06:48 PM | #14 |
Re: 15" Rims
15" tires are on their way out, like the 14s.
11-19-2020, 07:09 PM | #15 |
Re: 15" Rims
Older jeeps and dodge trucks
11-20-2020, 06:27 AM | #16 |
Re: 15" Rims
A while ago, I bought a set of 15" rims. Three of the four have "knubs" for the hub caps while the fourth has spring like fingers riveted on. Who made each of the two types?
Don't never get rid of nuthin! |
11-20-2020, 06:43 AM | #17 |
Re: 15" Rims
The one with the springs added, i have had them and they are mid 50s lincoln wheels. Original they were just smooth no clips because they had full size hubcaps
I have had them marked ford, fomoco and KH. |
11-20-2020, 08:12 AM | #18 |
Re: 15" Rims
https://www.summitracing.com/parts/w...estionsanswers
I bought 5 of these a couple of years back for my ‘41, got them on sale for $59. Each I think. Coker also has bare wheels also. https://www.cokertire.com/wheels/smo...r157lm400.html Last edited by corvette8n; 11-20-2020 at 10:59 AM. Reason: Added info |
11-21-2020, 09:41 AM | #19 |
Re: 15" Rims
Don't recall the width between the beads, but at least of passing interest the early Jeeps were 5-1/2" bolt pattern with the large center hole as required for 4x4 hub clearance, however they lacked the nubs for hub caps as the hubs protruded too far. I had once purchased a set of (5) NOS rims as mentioned, at an Army surplus outlet. Anyone on the hunt might ck. the 4 wheel drive & surplus outlets.
11-21-2020, 10:56 AM | #20 |
Re: 15" Rims
Another option would be the small Suzukis. I know my 95 Sidekick had 5 on 5 1/2" wheels similar to Jeep.
Al Hook |
