Old 10-06-2019, 07:22 PM   #1
Mulletwagon
Mulletwagon's Avatar
Default Speedometer Repair
The round Northeast speedometer in my 31 Tudor seems to show accurate speed, however, the last three numbers on the odometer are rubbed off. Is this a common problem and what are the options to fix ?
Mulletwagon is offline   Reply With Quote
Old 10-07-2019, 12:42 AM   #2
CarlG
CarlG's Avatar
Default Re: Speedometer Repair
Send it to one of the “professionals”. There are several that do good jobs at reasonable prices.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-07-2019, 09:59 AM   #3
Mark in MT
Odometer decals are easily available from most venders, but tricky to install and make look good. It is also a good idea to take odometer assy apart to clean, lube to make sure all is good for the future, same for the rest of the speedometer. Most speedometers die from lack of service, hard grease, lack of lubrication. Let me know if I can be of service.
Mark
[email protected]
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 10-07-2019, 10:00 AM   #4
old31
It really is not that difficult to buy the numbers decal kit and install your own clean looking numbers.
While you're in there you can clean it up the speedo.
Old 10-10-2019, 04:37 PM   #5
Bleedblue4life
Bleedblue4life's Avatar
I took apart, cleaned and oiled mine myself. Takes time and patience.
Bleedblue4life is offline   Reply With Quote
Old 10-10-2019, 06:54 PM   #6
History
History's Avatar
My speedometer works but the odometer doesn't, trip or overall. Any ideas what could be wrong? The numbers could be replaced also.
History is offline   Reply With Quote
Old 10-15-2019, 06:20 PM   #7
papanick
Yes if your speedometer need serviced get it rebuild and set for the next year. It sounds like the bushing has poped out that holds the drive gear in place. The hard grease dose that. I get them back in your hands with in 3 days. let me know if you need help. [email protected]
papanick is offline   Reply With Quote
