Old 04-19-2019, 11:04 AM   #1
Ricosan
Ricosan's Avatar
Default Spark plug for 34 aluminum head.
I have a 34 with the original aluminum heads. I have been using Champion D16s but they seem to foul after only a few hundred miles.
Anyone know what plugs are recommended for these heads?
Richard
Ricosan is offline   Reply With Quote
Old 04-19-2019, 11:31 AM   #2
supereal
supereal's Avatar
Default Re: Spark plug for 34 aluminum head.
It depends upon the type of fouling, oil or fuel. Oil fouling can usually be traced to leaking rings and/or valve guides. If it is a dry coating, check the carb for internal leakage such as warped gaskets, improper fuel level in the bowl, or a worn float needle or seat, Also check the float. A metal float can leak enough to admit internal fuel, and a plastic float can saturate and affect operation. Before looking for spark plugs, curing these possibilities is important.
supereal is offline   Reply With Quote
Old 04-19-2019, 11:38 AM   #3
40 Deluxe
Agree. Besides, if the plugs are gas fouled from a too rich mixture (dry "fluffy" carbon deposits), your whole engine is suffering. Unburned excess fuel is washing the oil off the cylinder walls, leading to premature wear of the cylinders, rings and pistons. Plus, your oil is being diluted with raw gas which means the bearings are not getting proper lube. This thinned out oil leaks and burns faster, too.
Old 04-19-2019, 01:05 PM   #4
Ricosan
Ricosan's Avatar
Trying to post a photo of the plugs but was unable to. I’ll try again when I get back to my computer.
Yes, it’s a fluffy dry coating.
The carburetor is one of the British built Stromberg 97. I put it on about 3months ago.
Richard
File Type: jpg 5A78D503-913D-46D5-A55E-FE60F1245F45.jpg (53.2 KB, 38 views)
Old 04-19-2019, 02:43 PM   #5
35fordtn
35fordtn's Avatar
Personally I like the Autolite 386's the best for the 1933-37 Fords. I had the same issues as you prior to swapping to Autolites.
35fordtn is offline   Reply With Quote
Old 04-19-2019, 04:48 PM   #6
Brian
Brian's Avatar
NGK A-6 are excellent plugs for these motors, but they have a bigger hex than your D16's
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 04-20-2019, 08:15 AM   #7
Ricosan
Ricosan's Avatar
Thanks guys,
I just got back from the auto parts store. I was going to try the autolite but the store didn’t have autolite 386. I ended up with with NGK AB-6. I plan to install this afternoon.
Richard
Old 04-20-2019, 09:29 AM   #8
KiWinUS
KiWinUS's Avatar
I use UD16s in my stock 36 engine. It runs great & plugs look amazing after 5000ml.
Old 04-20-2019, 01:38 PM   #9
Brian
Brian's Avatar
AB-6; I think the B stands for resistor, dunno if that'll make any difference?
Old 04-20-2019, 01:50 PM   #10
Ricosan
Ricosan's Avatar
I just got back from test drive with the new plugs. I wasn’t expecting it but I could actually feel a slight performance increase, especially in the higher PPMs. I’ll see how they look in 300 miles.
I had recommendations for Champion 7 which is also recommended in the Ford Service Bulletin for engines originally equipped with the aluminum heads but I can’t find any information on them. Autolite 386 was also Unavailable.
