Old 06-23-2016, 09:06 PM   #1
Phil Brown
Phil Brown's Avatar
Default Got Dads car a little closer to done today
Got the paint for the body finished up today for Dad's car. Used all SPI (Southern Polyurethanes Inc) products on it and man is that stuff nice to work with
Phil Brown is offline   Reply With Quote
Old 06-23-2016, 09:17 PM   #2
dennis lumbert
dennis lumbert's Avatar
Default Re: Got Dads car a little closer to done today
It looks fantastic .Enjoy thr fruits off your labor. Dennis
dennis lumbert is offline   Reply With Quote
Old 06-23-2016, 09:57 PM   #3
1930artdeco
1930artdeco's Avatar
Wow! Any shinier and you will be able to use it as mirror for all sorts of things, like shaving, brushing your teeth, starting fires from the reflection.....
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-23-2016, 10:05 PM   #4
Marshall V. Daut
When you put on the "leatherback" material and pin stripe the body, that'll really make the paint POP!
Marshall
Old 06-23-2016, 10:21 PM   #5
TinCup
TinCup's Avatar
That is going to be a beauty.
TinCup is offline   Reply With Quote
Old 06-23-2016, 10:27 PM   #6
Bulligen
Bulligen's Avatar
Very nice , Way to go !!
Bulligen is offline   Reply With Quote
Old 06-24-2016, 09:11 AM   #7
james hitchcock
james hitchcock's Avatar
Wow, looks like glass.
james hitchcock is offline   Reply With Quote
Old 06-24-2016, 11:22 AM   #8
Russ/40
Russ/40's Avatar
I'm curious, what type of gun you used. HVLP or standard? Did you color sand?
Russ/40 is offline   Reply With Quote
Old 06-24-2016, 11:45 AM   #9
Mitch//pa
Phil that baby looks HOT
Old 06-24-2016, 02:56 PM   #10
pgerhardt
pgerhardt's Avatar
Beautiful wet look. Base coat/clear coat I am guessing?
pgerhardt is offline   Reply With Quote
Old 06-24-2016, 03:21 PM   #11
mshmodela
mshmodela's Avatar
Mr. Brown...
Proper choice of color... Was waiting to see an all black Victoria... All she need is black wheels, black tires and thin red strip...
Very nice job!
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-24-2016, 03:35 PM   #12
henry's 31
Hi Phil:
It is looking GREAT. Great work and enjoy!
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 06-24-2016, 03:59 PM   #13
Tom Bellfoy
Tom Bellfoy's Avatar
I am assuming you installed inner fender wells, if this is the case can you tell me the part number as supplied by the parts dealers ? Were they the ones from the 4-door that fit ?
thanks
Tom Bellfoy is offline   Reply With Quote
Old 06-24-2016, 05:51 PM   #14
Phil Brown
Phil Brown's Avatar
It's a gravity feed HVLP Russ, and yea we color sanded and buffed it too give that black some more depth
Old 06-24-2016, 05:59 PM   #15
Phil Brown
Phil Brown's Avatar
Originally Posted by mshmodela View Post
Mr. Brown...
Very nice job!
That's the plan, the car had orig. black paint under a repaint of black when we got it. Never could find any of the orig. pin stripping, must have been sanded off for the repaint. And the wheels will be black
Old 06-24-2016, 06:08 PM   #16
Phil Brown
Phil Brown's Avatar
thanks
Yea the 4-door ones are close but not exactly right so they were just cut up and used parts of them where needed. More work but it kept them looking correct
Old 06-24-2016, 06:54 PM   #17
Russ/40
Russ/40's Avatar
You did a truly fine job. Its beautiful.
Old 06-24-2016, 07:52 PM   #18
Phil Brown
Phil Brown's Avatar
No it's a single stage polyurethane from SPI that's sanded and buffed (no clearcoat )
First time using SPI products and there stuff is great so easy to work with
