Old 11-14-2021, 05:21 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default aircraft type steel tubing
I just saw this term used in a posting on door lock set screws but I am not familiar with that term. I'm looking for a spacer/joiner tube with interior threads for a 3/16 OD rod. My local Ace guy can't help me. I am not sure he even understands me. I am attempting to cut a looooong "throttle rod" with the spring loaded ends and make a shorter adjustable one out of it. I do not know the correct nomenclature for the piece of interior threaded tubing I am looking for. Can anyone help with the nomenclature and source of such an animal? I hope I am clear as to what I am looking for and that someone can help me with a source. I just need a piece about 3" long. Thanks, Lawson
Old 11-14-2021, 05:37 PM   #2
rufus39
rufus39's Avatar
Default Re: aircraft type steel tubing
Lawson , is this in the Ballpark as to what you are looking for ?
Try this link....
https://www.mcmaster.com/threaded-tubes/length~3-16/
rufus39 is offline   Reply With Quote
Old 11-14-2021, 05:38 PM   #3
Dan in MI
Dan in MI's Avatar
Thy this:
https://www.mcmaster.com/internally-threaded-rods/
Dan in MI is offline   Reply With Quote
Old 11-14-2021, 05:49 PM   #4
PeteVS
PeteVS's Avatar
Thread sizes smaller than 1/4" are designated by a numerical size. So, except for Home Depot hardware, there isn't really a "3/16" thread size. That said, #10 threads are very close to being 3/16. For most US thread sizes, there are "coarse" threads and "fine" threads. #10 coarse threads are 24 threads per inch. Fine threads are 32 threads per inch. For each of these size/pitch combinations, there's a recommended "tap drill" size which will result in a good thread when tapped. For a #10-24 tap, using a #25 (.149) tap drill is recommended. If you use a smaller drill, it might be difficult to tap. If you use a slightly larger drill, it will be much easier to tap but the resulting thread might not have the desired strength to prevent being pulled out. Likewise, a #10-32 thread recommends using a #21 (.159) tap drill. Simplifying things, if you're looking for a tubing size to use without having to drill anything, try to find something with a 5/32 diameter. I'm thinking that 3/16 tubing for brake lines is going to be too small and 1/4 brake line tubing would be too big. Maybe you could braze a piece of 3/16 tubing into a length of 1/4", drill that out and tap it.
Sorry for the long winded explanation but....
Just saw Dan's response. Looks like he hit the nail on the head!
Old 11-14-2021, 06:17 PM   #5
johndee138
johndee138's Avatar
Look for coupling nuts at the hardware store
johndee138 is offline   Reply With Quote
Old 11-14-2021, 06:18 PM   #6
woodiewagon46
If you are joining threaded rod you can use "threaded rod coupler nut's". Any good hardware store has them and McMaster-Carr also has them.
woodiewagon46 is offline   Reply With Quote
Old 11-14-2021, 06:43 PM   #7
Bob C
Like Pete said your not going to find anything with 3/16" threads. 3/16" is .1875
a #8 screw is .164 and a #10 is .190. The 3/16" might work if it is slightly oversize.
I think this is what you are looking for. https://www.jegs.com/i/JEGS/555/157714/10002/-1
File Type: jpg Screen Shot 2021-11-14 at 3.50.58 PM.jpg (4.6 KB, 18 views)
Old 11-14-2021, 06:59 PM   #8
woodiewagon46
Lawson, if you google McMaster-Carr 90264A425, It's the same as what Bob C. is showing but smaller in length.
Old 11-14-2021, 08:47 PM   #9
Lawson Cox
Lawson Cox's Avatar
Hey, "All Y'all". As I have often said, this site is truly awesome, with a whole slew of knowledgeable folk just chomping at the bit to help others with all sorts of questions relating to flathead Fords, even the minutia. Thanks again to all who responded. McMaster Carr completely slipped my mind, and I have gone to them many times for many things. I'm calling them first thing in the morning.
Old 11-14-2021, 08:51 PM   #10
Jack E/NJ
Jack E/NJ's Avatar
Lawson >>>My local Ace guy can't help me. I am not sure he even understands me.>>>
I seem to vaguely recall a fix to similar dilemma not too long ago. Yep. I googled it. And here it is. Fellow said It should be easy enough to cut my NOS 18+ inch rod in two, thread it and use a threaded rod union to connect the two pieces back together.
https://www.fordbarn.com/forum/showthread.php?p=2071848
Old 11-14-2021, 09:08 PM   #11
Lawson Cox
Lawson Cox's Avatar
Hey Jack E/NJ. Thanks for the refresher course on just how much, and how quickly the aging mind forgets. Maybe I just need to hit the archives to see if I have previously asked a question before asking it, again. ROFLMAO. Lawson
A caveat if I might. My first posting was about how to make an adjustable rod where my current post is about where to obtain it the part. (Does that restore at least a part of my credibility? LOL
Old 11-14-2021, 10:16 PM   #12
38bill
38bill's Avatar
There is always this. They are slightly adjustable.
https://www.speedwaymotors.com/Searc...d%20connectors
38bill is offline   Reply With Quote
Old 11-14-2021, 11:54 PM   #13
GB SISSON
GB SISSON's Avatar
But didn't Dan get the answer back in post #3? the 10/24 internally threaded rod? Maybe I'm missing something. It happens a lot
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-15-2021, 07:43 AM   #14
Jack E/NJ
Jack E/NJ's Avatar
Unlike internally threaded tubes, internally threaded rods haven't been invented yet. 8^)
Old 11-15-2021, 10:36 AM   #15
rotorwrench
rotorwrench's Avatar
In aerospace hardware, a -3 or 3/16" bolt has a 10/32 thread. There are some Heim type spherical rod ends that are actually made with that small a thread and are generally used in engine throttle controls. Most are sizes 1/4-28 or larger but the 10/32 are the smallest ones I've seen.
When folks refer to aircraft steel tubing, they are generally referring to thin wall chrome molly steel structural tubing used to build aircraft tube frame structures for fuselages and engine mounts. Each successively larger size will fit inside the next size up. Wall thickness varies so most ID/OD sizes follow the wall thickness.
Old 11-15-2021, 01:03 PM   #16
Lawson Cox
Lawson Cox's Avatar
Thanks. That's good info to have.
Old 11-15-2021, 02:13 PM   #17
BoxCar Tom
BoxCar Tom's Avatar
don't you want a turnbuckle so that when you turn it one way it gets shorter, turn it the opposite it gets longer?
BoxCar Tom is offline   Reply With Quote
Old 11-15-2021, 02:42 PM   #18
Lawson Cox
Lawson Cox's Avatar
Yes. I guess. . I'm just thinking of a threaded tube, OD about 5/16 and tapped for a 10/24 threaded rod. I need it about 3" long. That's about all I can wrap my mind around right now. (Grin)
Old 11-15-2021, 03:31 PM   #19
GB SISSON
GB SISSON's Avatar
I think McMaster-Carr just invented them, but I get it. They really should have called it a tube.
Old 11-15-2021, 03:34 PM   #20
Jack E/NJ
Jack E/NJ's Avatar
Lowes has just what you want Lawson. For a $1.98. It's an extruded threaded tube that looks like a turnbuckle. They have other sizes too. You can have a long chat with the nice lady on line to try to get whatever you want. 8^)
