Old 10-28-2016, 09:13 PM   #1
tinman7
tinman7's Avatar
Default Jack stands
My first post, I am going south for six months was wondering if I should put my A up on jack stands and if so where is the best spots to place them?
tinman7 is offline   Reply With Quote
Old 10-28-2016, 09:44 PM   #2
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
Default Re: Jack stands
Tinman I put my 29 on Jackstands every Winter . I put stand under front axle by spring shakle. In back I set the stands out towards the backing plates on the rear end housing. Just make sure level and good ! hope this helps
Indiana A. Lover is offline   Reply With Quote
Old 10-28-2016, 10:14 PM   #3
C26Pinelake
Welcome to the barn and hopefully you will make many more posts! The answer to your question is as above. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-28-2016, 10:37 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Welcome to the barn!
As for jack stands, some do some don't, use them over the winter.
Old 10-28-2016, 10:45 PM   #5
1crosscut
1crosscut's Avatar
Put your jack stands inside 5 gallon buckets and set them as high as you can. Will help keep mice from climbing up the stands and getting inside. May not be 100 percent effective but should help.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-29-2016, 05:48 AM   #6
Dollar Bill
Dollar Bill's Avatar
Welcome to the Barn!
If you have nylon tires, taking the weight off will prevent flat spots.
If it were me, I would place jack stands against the frame. Front, near flywheel cover and in rear by the rear running board support brackets. Jack stands on the frame will give leaf springs a rest.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 10-29-2016, 07:13 PM   #7
Capt Quahog
Capt Quahog's Avatar
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
For the two operational vintage cars that we own, in the winter every couple of weeks or so I go out, start em', run em' and sometimes drive the vehicles around the circle here. Twice around is about a mile distance. The A Model Ford and old Mercedes diesel seem to like the exercise. From experience . . . if a car sits unused for even a relatively short time, the machine starts to deteriorate faster than if in use.
I wouldn't be so paranoid if people weren't plotting against me all the time
Capt Quahog is offline   Reply With Quote
