Old 04-15-2021, 04:04 PM   #1
GSCOV
Default gas tank 1933 pickup
Hey Barners - looking for advise on replacing the gas tank on my 33 pickup. It is stock Model B. Very nice rust free clean truck. Restored vehicle but no history on work done. Obviously they painted the outside of the tank and ran a new copper line, but inside is dirty. Truck died and found the line was plugged. Blew thru it with compressed air. Drained the 9 gallons in the tank and it was rust colored and large particles deposited on the cheese cloth on the funnel. Who makes a stock replacement? Thanks.
GSCOV is offline   Reply With Quote
Old 04-15-2021, 04:20 PM   #2
jimTN
Default Re: gas tank 1933 pickup
Have a radiator shop treat it with muriatic acid (swimming pool acid) and have them then clean and coat with a good alch. resistant lining.
jimTN is online now   Reply With Quote
Old 04-15-2021, 07:01 PM   #3
TJ
TJ's Avatar
Shop around and buy a new tank. You'll be glad you did. Check with Tanks Inc. On e-Bay there are new tanks for your pickup from $250-$350. Would probably cost that much to fix your old tank if you could find a shop that would do it. A new tank has not been compromised by rust. JMHO but a new tank is money well spent.
Old 04-15-2021, 08:30 PM   #4
Newc
Newc's Avatar
Just understand - NO sealer on the filler threads- the lead rings do the sealing. Newc
Old 04-15-2021, 08:57 PM   #5
cas3
And, the new tank will most likely not accept your 33 gas gauge sending unit. Myself, I would clean the original if its not rusted to death
Old 04-15-2021, 09:00 PM   #6
totto
totto's Avatar
I did what JimTN did with my '34 gas tank. I use a "glass bowel" fuel pump to "have a filter" from tank to carb.
Henry
totto is offline   Reply With Quote
Old 04-15-2021, 09:21 PM   #7
cas3
I have been a believer in sediment bowls most of my life, but in truth they let alot of fine particles pass thru. One of my model A's has some minor rust issues. This car gets a lot of miles, even in winter. About every three months it would run crappy, so I would just take the top off the carb and blow it all out. there was very fine silt in the bowl always, an easy job on an A. So then, i put on an inline filter, one I had in stock. It was one of those glass things that you can unscrew the ends and clean the fine screen inside. Better, but still very fine stuff in the carb bowl. Now, a paper inline filter and no trouble in 2 years. I do blow all the crud out backwards on every oil change though
Old 04-16-2021, 04:40 AM   #8
GSCOV
The time involved with running it to and from a radiator shop and then more maintenance is not what I need. Want a one and done go on with life fix. TJ and I are on the same page. This looks like a treat just to get the tank out and not going to do it a second time. My question was what vendor had the closest match to what I have. Mine is smooth on the bottom and the ones I have seen to replace it have ribs. And the top holes?
Old 04-16-2021, 05:26 AM   #9
Ggmac
Im in the same situation, with a 41 tudor , my thinking is that a new tanks aren’t always going to be available. So im going to buy new , searching for the best deal .
Good luck and be careful
Old 04-16-2021, 07:52 AM   #10
bigdoor
buy a new one I put one in my 34 2 years ago from tanks the fit was good the price was good
bigdoor is offline   Reply With Quote
Old 04-16-2021, 09:44 AM   #11
TJ
TJ's Avatar
Check with Michael Driskell at 3rd Gen Automotive. I'll bet he can get a new tank for you.
Old 04-16-2021, 10:22 AM   #12
deuce lover
deuce lover's Avatar
mistake
Old 04-16-2021, 10:28 AM   #13
35fordtn
35fordtn's Avatar
You can use a 1935-37 Pickup tank in the 33-34 as well as 34 victoria. They accept a electric sending unit but a adapter is available to adapt your original sending unit. On these I would only use a drake tank. We stock and sell them and have had zero issues.
Old 04-17-2021, 06:53 AM   #14
Ken/Alabama
Ken/Alabama's Avatar
Google Moyer fuel tank renew located in Greensburg Pa. They’ve done a couple tanks for me. They do great work .
Old 04-18-2021, 12:46 AM   #15
al's28/33
al's28/33's Avatar
I got mine from Bob Drake in 2005. The victoria style tank fits 33-34 pickups.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 04-29-2021, 05:53 AM   #16
hermitrob
hermitrob's Avatar
https://bobdrake.com/search?type=pro...=1933+gas+tank
Bob Drake has gas tanks
Rob
Vermont
Pretty don't get you home
I would rather ask a stupid question than do something stupid
hermitrob is offline   Reply With Quote
Old 04-30-2021, 04:25 AM   #17
GSCOV
Thanks all -but the tank was not my issue. Simply some foreign matter in the tank. Looks like someone used a can with smutz in it. Tank was restored with the truck and is clean.
Old 04-30-2021, 07:28 AM   #18
Ggmac
I just replaced my 41s tank . After shopping around , Bob Drake was the cheapest and the manufacturer, $17 ground shipping across the country , arrived in 5 days undammaged and just finished installing . Excellent product, so far .
My old tank was well past its date .
I also replaced the fuel line , cleaned and checked fuel pump and carb . Remember to get the filler neck hose .
Old 04-30-2021, 05:15 PM   #19
34pickup
34pickup's Avatar
I replaced the tank in my 48 with a Tank's repro unit. It fit perfectly but I was disappointed in the fact that they do not come with a drain plug in the bottom. I think that would come in handy with old cars/trucks that sit for extended periods.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 04-30-2021, 06:41 PM   #20
Ggmac
Mine had a drain plug but did require a $30 riser to use the original KS sender .
