Old 01-15-2023, 10:13 AM   #1
rwh
Default New model A U-joints
Hello,
Model A u-joints seem to be back order ?
Anyone know a source?
Thanks,
Richard
rwh is offline   Reply With Quote
Old 01-15-2023, 10:22 AM   #2
Ordsgt
Ordsgt's Avatar
Default Re: New model A U-joints
Careful what you buy as a lot of the previous available U Joints would not fit in the clamshell of model A's.
Ordsgt is offline   Reply With Quote
Old 01-15-2023, 10:59 AM   #3
rwh
Thanks
Old 01-15-2023, 11:47 AM   #4
Bob C
The one on the left is the problem one.
Old 01-15-2023, 02:22 PM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
This is another example of why we will miss Macs/Eklers/Specialized. They were the supplier manufacturing the reproduction rebuild kits that allowed you to rebuild an original U-Joint.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-15-2023, 02:48 PM   #6
Ordsgt
Ordsgt's Avatar
Brent,
I always appreciate your posts but in this case the last U joint I got that didn't fit was from Macs / Eklers
Old 01-15-2023, 04:39 PM   #7
BRENT in 10-uh-C
Originally Posted by Ordsgt View Post
Brent,
I understand what you are suggesting totally about buying/using the repro U-Joint ...and I agree with you 110% however what I was trying to imply was they were the sole supplier of the rebuild kits which we were using to rebuild original Universal Joints.
FWIW, I have made several of the repro joints work after about 30 minutes in the lathe. Not sure if the backorder is due to re-tooling or just supply chain delays.
BRENT in 10-uh-C
Old 01-15-2023, 07:41 PM   #8
Ordsgt
Ordsgt's Avatar
I was not aware you could rebuild the original. The fact they are riveted together and never seeing a kit coupled with hearing and seeing articles that they were not rebuild able sure reinforced that to me. Did that kit come with new rivets
Old 01-15-2023, 08:17 PM   #9
jeepguy1948
I have (2) 1948 Lincoln needle bearing U joints I will sell. I paid $100 plus shipping each for them and that’s what I will sell them for. 1948 was the last year that Lincoln used a torque tube and for that one year they used a needle bearing U joint. They WILL fit in the clamshell. They are not new but they are in as new condition.
jeepguy1948 is offline   Reply With Quote
Old 01-15-2023, 09:00 PM   #10
Ray in La Mesa
Not all join's were riveted.
Ray in La Mesa is offline   Reply With Quote
Old 01-16-2023, 04:42 PM   #11
Synchro909
Synchro909's Avatar
I rebuilt one years ago by removing the rivets and replacing them with high tensile bolts. It is still working well.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-16-2023, 07:07 PM   #12
alexiskai
alexiskai's Avatar
As if on cue, this fellow is selling some:
https://www.fordbarn.com/forum/showthread.php?t=322418
Old 01-17-2023, 09:28 AM   #13
springerpete
springerpete's Avatar
Try Bert's in Denver. They probably have a good used one or a rebuilt one. They are a wonderful parts source.
springerpete is offline   Reply With Quote
Old 01-18-2023, 09:59 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
The U-joint on the left is a Ford original Model "A" U-joint and it is not rebuildable. The Spicer U-joint in the middle replaced the one on the left for service, it is rebuildable, and it is a far better design. The photo on the right is the rebuild kit for the Spicer U-joint.
File Type: jpg X_SPL250_U-Joint_ShowingNeedleSpacerExploded.jpg (26.9 KB, 39 views)
Bob Bidonde
Old 01-18-2023, 10:38 AM   #15
BRENT in 10-uh-C
Originally Posted by Bob Bidonde View Post
The U-joint on the left is a Ford original Model "A" U-joint and ...is not rebuildable. The Spicer U-joint in the middle replaced the one on the left for service, it is rebuildable, and it is a far better design. The photo on the right is the rebuild kit for the Spicer U-joint.
Ohh Really? Why not??
BRENT in 10-uh-C
Old 01-18-2023, 01:39 PM   #16
jeepguy1948
Terry, I know that you have probably forgotten more about Model As then I will ever know. That said however, you are rude, condescending, and just plain not a nice person. I know some 8 year olds like that,
Old 01-18-2023, 01:43 PM   #17
jeepguy1948
Bob, I really appreciate the good advice that you provide and the fact that you frequently provide pictures and other attachments to help explain what you are trying to convey. Continue to fly with the eagles and don’t let the vultures get you down.
Old 01-18-2023, 03:36 PM   #18
Hitman
Is Brent wrong? "Synchro909" above even mentioned he rebuilt the early, riveted style.
I think correcting the spread of misinformation is better than the perception of one's behavior in a response. The early, riveted style can in fact be rebuilt.
Hitman is offline   Reply With Quote
Old 01-18-2023, 06:29 PM   #19
Synchro909
Synchro909's Avatar
Yes, I rebuilt one. I have said here many times that you guys don't know how good you have it. The supply of parts here was nothing like what you have so we had to fix things that are in all reality, past it. When I did the universal joint, I could not lay my hands on a decent replacement so I had no option. It worked out OK but not worth the effort. I wouldn't do it again. It wasn't easy.
Repairable? Yes. Economically worthwhile? No.
Old 01-19-2023, 07:22 AM   #20
BRENT in 10-uh-C
Well I am unsure what brought this on as I sure did/do not see where I was rude to anyone however please accept my public apologies if you felt I was rude or condescending towards you. You are welcome to PM me if you feel this is not acceptable and I will work towards making it right with you off-line and not disrupt someone else's post with this. BTW, Bob and I are social media friends and have a good relationship outside of Fordbarn. I definitely was not being those things you described, ...but again you don't know me outside of judging me off of what you perceive me to be.
BRENT in 10-uh-C
