Old 09-05-2013, 12:19 AM   #1
HarryMichael
Default 1934 5 window coupe (sorry guys)
Sorry guys just noticed the typo I need details on seat risers / sliders ans the "saw tooth ratchet " that locks the seat I place anyone have a pic or diagram or knows how it all goes together just have a basket case. Any help is appreciated thanks!,,.
HarryMichael is offline   Reply With Quote
Old 09-05-2013, 02:53 PM   #2
Mike in AZ
Mike in AZ's Avatar
Default Re: 1934 5 window coupe (sorry guys)
good luck......when you post, or after you post; if you notice an error, try going to the bottom of your post and hit edit....i know you can edit in the body of your post, don't know about editing the headline.....good luck with your search....Mike
Mike in AZ is offline   Reply With Quote
Old 09-05-2013, 03:28 PM   #3
Terry,OH
Terry,OH's Avatar
34 is basically the same as 35 with the rods, and the handle faces the passenger. I believe the saw tooth type is 33. The 35 style handle mounts to a piece of wood that strengthens the front of the seat pan but 34 the handle mounts directly to the pan, making the front of the 34 seat pan a bit weak in this area and they often crack and flex in the handle area. The 34 seat adjusters are not as tall as the 35. There may be a second seat adjuster type for 34 It uses rollers versus the ball bearing style.
Old 09-06-2013, 09:50 PM   #4
HarryMichael
Thanks to all the guys that helped that's why this is such a grat hobby Thanks again
Old 11-30-2013, 11:26 AM   #5
1936ford64
The saw tooth type adjuster was used from late 1930 thru 1934. The style changed with the 1935 model year. A quality reproduction assembly with everything you need has been available for many years for $ 125.00 but he doesn't advertise. contact [email protected]
1936ford64 is offline   Reply With Quote
