11-28-2019, 05:36 PM | #1 |
Knocking at start up?
What would cause a knock at startup? The knock is only for about 20-30 seconds, then it stops.
After startup, it does not matter where the spark lever is positioned. |
11-28-2019, 05:58 PM | #2 |
Re: Knocking at start up?
center main is one but it depends on the sound.
11-28-2019, 06:25 PM | #3 |
Maybe a sticking valve. Might try Marvel Mystery Oil first.
11-28-2019, 06:25 PM | #4 |
Piston slap, until oil gets up into cylinder, and pistons warm up. If it is more noisy when cold than warm, this may be it.
Mark in MT Always looking for another opportunity to be wrong. |
11-28-2019, 06:31 PM | #5 |
Make a stethescope with a long rod of some kind and put it on the engine while it’s running. You will be amazed at what you hear going on in there. My roadster knocks to until it warms up. I’m sure it’s a main bearing I’ll have to address it sometime in the near future . Frank
11-28-2019, 07:59 PM | #6 |
This usually only happens with babbet bearings and not insert bearings. This usually happens after the car sets overnight or longer and not after being shut off for just an hour or so. 10/40 or 20/50 oil may help. I ran an engine for several years like this and it did not get any worse. I was too lazy to drop the pan and take up the bearings. Just run the engine slow and do not put any load on the engine until the oil gets pumped up. Chris W. Last edited by CWPASADENA; 11-28-2019 at 08:01 PM. Reason: CLARIFICATION |
11-28-2019, 08:28 PM | #7 |
I too would think its probably the center main. But a stethoscope could help pinpoint where the noise is coming from.
The lever should be up for starting and upon start up it should be pulled 1/2-3/4 way down. |
11-28-2019, 09:33 PM | #8 |
Too much slop in the thrust bearing caused just that in an engine I had. Test this theory by not pressing the clutch before starting up the car next time.
11-28-2019, 11:35 PM | #9 |
I had something similar, only when cold, but gradually got worse over a couple of thousand miles. Ended up being a crack rod cap, Because I waited and then had the motor rebuilt, teh rebuilder had to bore the cylinders from .020 to .080 over due to wear issues caused by the cracked rod cap. So my advice is do not wait, find out what the problem is asap, am now a big believer in if there is an issue identify it sooner than later.
11-29-2019, 04:54 AM | #10 |
11-29-2019, 04:57 AM | #11 |
OK, I will try this and report back.
11-29-2019, 09:44 AM | #12 |
I’d say pull the oil pan and look it over. For a quick test, buy a bottle of Slick 50 and put it in. I imagine I’ve just woke up the scoffers with that comment but if you have a worn engine it DEFINITELY will help. A Teflon film on the bearings will keep the squirrel rattlers quiet.
11-30-2019, 11:03 AM | #13 |
I had an engine like that also that had the piston slap when it was first started cold. It had been re-ringed when it first should have been re-bored.
11-30-2019, 05:18 PM | #14 |
i can measure my thrust with a tape measure and i have no knock
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
11-30-2019, 10:21 PM | #15 |
I have a tendency to agree with some of the guys. To much main bearing clearance can cause noise until oil lubes the crank.
12-01-2019, 10:41 AM | #16 |
12-04-2019, 09:09 AM | #17 |
J. your theory shows it does not knock when the clutch is not depressed on startup.
So, how is this fixed? If it doesn't hurt anything I won't bother. |
12-04-2019, 09:25 AM | #18 |
Check your private messages on this website.
Marshall |
12-04-2019, 01:42 PM | #19 |
Too much end play can cause the crank to be pushed forward and make the rods mis-align. Things tend to find centers after it gets running and oiled. Play in the thrust area can be measured and repaired.
12-05-2019, 08:50 AM | #20 |
On my old engine, pushing the clutch in before startup would result in a loud clunk. The thrust was very worn and the crank would move about 1/16"... knocked louder from the center main and disintegrating #4 rod bearing though.
