10-19-2012, 01:32 PM | #1 |
what the scoop on these spindels?
Here is a pic of my 34 spindels, steering side has a ring at the base of the axle but not on pass side. should both have them and purpose? I have another set just opposite from a 33. Ken
10-19-2012, 01:35 PM | #2 |
Re: what the scoop on these spindels?
thats where part of the mechanical brakes were
10-19-2012, 01:52 PM | #3 |
That is the oil seal. The early cars did not use a lip seal. It is also why they came with the grease retainer ring. Pull them off when coverting to later hubs with grease seals.
10-19-2012, 03:00 PM | #4 |
Andy is correct that's the grease seal for the hub just take a screw driver as a pry tool and pop it off the spindle snout.
dickspadaro.com |
10-19-2012, 11:41 PM | #5 |
So i dont need them? is there a modern seal I should have there? I plan on using the original setup and mechanical brakes. Ken
10-20-2012, 01:45 AM | #6 |
10-20-2012, 06:40 AM | #7 |
Mac's has them Pt# b1190 (cheap ones) b1190u (good ones). I was like you when I took my 34 apart it was not the type of grease seal I was used to. Live & learn I guess.
Gary. |
10-20-2012, 09:46 AM | #8 |
That would be the dust shield …. Keeps the big stuff off the seal
