09-12-2021, 05:45 PM | #21 |
Re: red liquid fuel gauge?
I’ve bought from them several years ago but when I checked this year, I couldn’t find it on their site which was easily located when I bought it before.
09-12-2021, 08:37 PM | #22 |
The original Ford red fluid has come up on Ebay now and again and it is the same fluid that is used in the Temperature gauge. I wonder if the gauge would still work if you fitted a little red ball.
09-12-2021, 11:26 PM | #23 |
'I wonder if the gauge would still work if you fitted a little red ball'
in order for the liquid in the sightglass to show true level in gastank, it MUST have a sg of 2.95
09-13-2021, 06:11 AM | #24 |
Good idea Brian. A small glass bead would work, not sure about plastics.
Glenn |
09-17-2021, 09:49 AM | #25 | |
Thank you - highbeams Last edited by highbeams; 09-18-2021 at 03:20 PM. Reason: clarification |
09-17-2021, 10:03 AM | #26 |
Deuce Roadster: Would you please clarify your comment regarding the reasons as you factually acknowledge them. Thank you in advance. highbeams |
09-17-2021, 10:09 AM | #27 | |
Are you suggesting an exact diameter? Obviously; correct? Would you update your findings, please? Thank you in advance -highbeams |
09-17-2021, 02:17 PM | #28 |
The ball wasn't my idea, I was simply responding to Ian's post #22
09-18-2021, 03:08 PM | #29 | |
Do you have a '33 glass fuel tube handy out of a car to measure the inside diameter? Thank you - highbeams |
09-18-2021, 03:17 PM | #30 | |
Do you know the inside diameter of the glass fuel gauge? thank you - highbeams |
09-18-2021, 04:37 PM | #31 |
"Do you know the inside diameter of the glass fuel gauge?"
I just measured the ID on an old broken gauge I have and then checked it with a drill bit. ID is 9/64" Glenn |
09-18-2021, 05:25 PM | #32 |
I would use a bead of 1/8" OD.
This is just an example since I doubt the Coral would withstand the acid. https://www.michaels.com/bead-galler.../10120972.html Last edited by glennpm; 09-18-2021 at 06:37 PM. Reason: Make clear that I’m not suggesting that coral is appropriate |
09-18-2021, 07:28 PM | #33 | |
I was under the impression that the ball to be used, as opposed to the 'red'; re your comment "I doubt the coral would withstand the acid." Thank you, Sir. highbeams. *** Last edited by highbeams; 09-19-2021 at 02:03 PM. |
09-18-2021, 07:40 PM | #34 | |
Sincerely appreciated. So, hopefully, the hydrastatic pressure will coincide w/the fuel level in the tank and push the 9/64" glass ball to the accurate position. THAT WOULD BE SPLENDID! As opposed to diddling with the 'red'. Correct me if I am misunderstanding. I've been known to uh, misunderstand, particularly with a honeydo. https://thefractioncalculator.com/ 2:04 PM Pat Malone Last edited by highbeams; 09-19-2021 at 04:17 PM. |
09-18-2021, 09:22 PM | #35 |
What's the specific gravity of glass? I hope it's less than 2.95 or else it will sink to the bottom of the gauge.
09-19-2021, 06:28 AM | #36 |
Yes, good question and I checked it the other day.
Glass beads 2.5 SG https://www.engineeringtoolbox.com/s...als-d_293.html |
09-19-2021, 04:46 PM | #37 |
It would be easy to test the ball just put it into some of that fluid in a phial and see if it sinks.
09-19-2021, 06:45 PM | #38 | |
Thanks so much for that. Pat Malone |
09-19-2021, 08:19 PM | #39 | |
The glass-ball idea is the best. re: https://www.jansjewels.com/3.5mm-No-...ds_p_3583.html glass tube i.d. is 9/64" or 3.571 mm. |
09-19-2021, 08:23 PM | #40 | |
