Old 04-05-2021, 07:58 AM   #1
Huff
Send a message via ICQ to Huff Send a message via AIM to Huff
Default 52 Ford F1 spare tire carrier.
I want to put my spare tire in the factory location . I will be using the Ford 15 inch rim. The rim is 5 1/2 inch wide. What I need help with I want to use a narrow tire on that rim. Can some one tell what size to use.Would a 195/75/15 fit on my rim or must I use a 205/75/15?Thanks in advance.
Huff is offline   Reply With Quote
Old 04-05-2021, 12:52 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: 52 Ford F1 spare tire carrier.
A lot of guys run the 195/75's all around on the stock 4.5" rims. I don't think it would be a problem on 5.5", but the tire shop could tell you for sure.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
