02-11-2020, 12:36 AM | #1 |
'54 / '55 Fordomatic ID ?
I have an air-cooled Fordomatic in a '55 Bird that the transmission rebuild shop said is a two speed. When driving or being manually shifted it only shifts one time.
It was my understanding the original air-cooled auto trans for a '55 Bird 'should' be a 3 speed that normally just skips first gear unless manually shifted, or kicked down. Same with the '56 & '57 Ford-o transmissions. But, the transmission info at this link says the automatic is two speed, and the same for '56 & '57 Birds. http://automotivemileposts.com/tbird/prod1955tbird.html I'm confused. Was the '54 Fordomatic a two speed? How would I easily tell them apart if they're different from the air-cooled '55 version? I remember the ID tag on the trans being blank when I was looking at it a few years back. Are there other numbers or letters cast into the trans that would be different? The car had a '54 engine when I got it and the transmission may(?) have come with the engine. OR, am I lost and barking up the wrong tree? . Last edited by dmsfrr; 02-11-2020 at 01:21 AM. |
02-11-2020, 05:56 AM | #2 | |
Re: '54 / '55 Fordomatic ID ?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
02-11-2020, 10:34 AM | #3 |
the 54 was-is a 3 speed sorry not about to crawl under to check for I.D.tags etc.if you like the idea of shifting pull it into low run it to about 25 pop into drive and carry on.if done right you can chirp the tires
02-11-2020, 11:03 AM | #4 | |
Incidentally, is your T-Bird a very early production car? If so, it may have had that 256 engine from the factory. There is an article in a 1954 Popular Mechanics magazine (about April or May, I think) that talks about the upcoming Thunderbird and lists the engine as the 256. |
02-11-2020, 11:32 AM | #5 |
I think the 256 Merc Y-Block in early '55 T-Birds might just be an old wives tale. Why would the use an inferior less powerful engine in a Bird if the 272 was available from the start of '55 production ?
Sal |
02-11-2020, 12:32 PM | #6 |
http://www.oldcarbrochures.com/stati...Folder-06.html Even the earliest production '55 TBirds had the 292... "For 1955, the first 1000 Dearborn-built Ford VINs - 100001 through 101000 - were reserved for the new Thunderbird. All of these cars had the same 292 cubic-inch V-8 engine (P) . . . " http://www.tbird.info/first-1955-thunderbirds.htm The one I have is slightly later than this earliest group, scheduled build date Nov. 9th of '54. I suspect one of the previous owners may have worn out / used up the original 292 engine. Or... Back-in-the-day the car was in a bad enough wreck to have the frame replaced. Maybe the original engine & transmission were borrowed for another project at the time. The '54 Merc 256 EBY engine in the car had a '57 tach drive distributor, '57 ECZ-B intake and an Autolite carb from an FE 390 when I got it. It didn't run well at all. Maybe a vacuum leak from the mis-matched intake manifold? List of Y-block engine block casting number prefixes by year... http://www.ford-y-block.com/Block%20identification.htm 40 Deluxe yes it's odd they didn't list the 1:1 high gear. I missed that, thanks. I've seen the same transmission specs on at least one other website. Maybe they're just copying the info from each other??? On the left side of this linked '55 Thunderbird info page... (photo attached) http://automotivemileposts.com/tbird/prod1955tbird.html . Last edited by dmsfrr; 04-17-2020 at 12:06 PM. |
02-11-2020, 12:46 PM | #7 | |
On the photo you show, again it lists the low gear and 2nd gear ratios, but not the 3rd gear ratio of 1 to 1. |
02-11-2020, 12:46 PM | #8 | |
Attached are excerpts from an introductory BIRD BROCHURE. No publication date-
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 02-11-2020 at 02:06 PM. |
02-11-2020, 01:00 PM | #9 |
The FORD-O-MATIC was a three speed transmission. It is what is known as a SINGLE RANGE whereas the CRUISE-O-MATIC (1958/ ) was deemed DUAL RANGE.
The FM started in 2nd for fuel economy purposes. If you wanted performance, you either pull it into low or gagged it. Brief and Concise Description - http://www.charlietranny.com/Fordomatic.htm
02-11-2020, 01:05 PM | #10 |
It is assumed FINAL is 1:1 unless an OD.
02-11-2020, 01:29 PM | #11 | |
So the engine was documented (CASTING ID - DATE CODES) as a 256 EBY? Regarding the ECZ-B intake, were there any vacuum leaks as while the EBY was a CF design, it also had the smaller heads.
02-11-2020, 04:02 PM | #12 | |
I didn't note or take photos of the date code because I wasn't that concerned. Just sold it to the first person who wanted it. Vacuum leaks? The idle was real erratic and if I didn't slip it into neutral and keep it reved up it would die at every stop. I didn't do any diagnostics on the engine since I wasn't keeping it, was more concerned with getting it out and finding a good replacement. Initial topic... I'm not happy with the apparent 2 speed transmission. The car seems a bit sluggish and doesn't take off well in its Lo gear (shakes & makes squealing noises occasionally unless I shift it manually) and RPM on the road is higher than I'd like. With all the trouble to take it out I'd almost prefer to swap it for something better, maybe AOD? I still need to double check the ignition timing & distributor operation after its initial setup, also the head bolt torque(?) valve adjustment and oil change. The replacement 292 has just turned its first 1000 miles. . Last edited by dmsfrr; 02-20-2020 at 07:21 PM. |
02-11-2020, 04:46 PM | #13 | |
AOD = $$$ but makes sense.
02-11-2020, 05:16 PM | #14 | |
It was a rebuild of the trans that came with the car. It's been back to the shop since then. They said they dropped the pan to check it out and made some adjustments. Still seems the same to me. |
02-11-2020, 05:23 PM | #15 |
Were you able to ID the TRANS? It may be calibrated incorrectly.
02-11-2020, 06:06 PM | #16 |
02-12-2020, 10:11 AM | #17 |
1955 FORD THUNDERBIRD SALES BROCHURE EXCERPT
(No Pub Date) -
02-17-2020, 09:49 PM | #18 |
I don't know as much as I'd like to. At the moment I can't get the car high enough off the floor to really be able to get under it.
Tried to measure "A", the length of the main case and got 10 & 1/2 inches. So not accurate enough with one hand and a tape measure??? However, at this website http://www.charlietranny.com/Fordomatic.htm I did find an image that looks like the same pan/pan gasket, with 14 bolt holes. (photo 1 below) The inset corner is at the front of the driver's side of the trans. The main case is cast iron. I didn't find a picture of an air cooled Ford-O like this one on that website, but found one I took a while back. I'll make another attempt to get underneath after I get more jackstands. Last edited by dmsfrr; 02-18-2020 at 11:08 PM. |
02-17-2020, 11:32 PM | #19 |
You have a typical small-case two speed Ford-O-Matic. They were commonly used for Ford full-sized cars V8 and 6-cyl applications beginning in 1951.
The 1951 thru 1954 Ford-O-Matic's had a cast-iron rear extension housing. From '55 on up, they had an aluminum rear extension housing. '51 thru '56 had air-cooled converters. '57 and later (with V8) had water-cooled converters, but they kept the air-cooled converters for the 223 I-6 all the way thru to '64 I think (when the 223 was discontinued). If I remember right, the Cruise-O-Matic had a slightly longer case (known as the medium case). The transmission fluid pan was shaped a little differently and had a little bumpout on the passenger side. That has always been the easiest way for me to determine the difference. The Cruise-O was normally not used on full-sized cars, but they were installed in Mercury cars and wagons and they were installed in Ford Thunderbird's. I just don't know what year they started. The '55 T-bird came from the factory with a 292 as the 312 was still a year out yet. Lincoln had a whole nuther animal, known as the large case Ford-O, and if you saw one of those, you could easily tell the difference without measuring. |
02-18-2020, 12:09 AM | #20 | |
My biggest concern is why it seems to only have two functioning forward gears instead of three with a 2nd gear start as I've been told it 'should' be. I asked the transmission shop that did the rebuild the same question and they told me it's really just a 2 speed. So where did the other gear go??? Shifting manually or driving it has two forward speeds and shifts only once. I initially thought the shifter might be out of position relative to the transmission and it may not reach the actual Lo gear position (since starting up from a stop seems a bit sluggish and at times squeals and shakes the car) but it lines up with the P R N D L letters just fine. I'll double check that adjustment too. . Last edited by dmsfrr; 02-18-2020 at 12:49 AM. |
