11-06-2014, 08:39 PM | #1 |
Tillotson Carb Question
The screwdriver slot is stripped in the small brass jet in the bottom of the carb bowl. Im goin to try to drill it out...does anyone know what size tap I'll need to clean out the threads?
11-06-2014, 09:00 PM | #2 |
Re: Tillotson Carb Question
Try a left hand set of drill bits and go slow. The bit may bite and spin the jet out.
It did for me, and Harbor Freight sells left hand bits. |
11-06-2014, 09:30 PM | #3 |
Hey thanks Tom ! I'll be goin to Harbor Freight Sat !
11-06-2014, 10:21 PM | #4 |
I had the same scenario. I used a small easy out after soaking it for a day in PB blaster and it came out easily.
11-06-2014, 10:23 PM | #5 |
Go with what Tom say's, but I believe the jet thread is 8/32.
11-07-2014, 06:01 AM | #6 |
11-08-2014, 11:20 PM | #7 |
Thanks Tom Wesenburg...the reverse drill bits did the trick!
