Old 06-27-2011, 10:51 AM   #1
jetrod
Default Fuel problem- When restarting hot motor
Hey, When my engine is hot and then shut off for a short time, then I go to restart it-- the engine quits after about 100 yards. Let it set for 5 minutes or so and it takes off like nothing ever happened!! It acts like the gas shutoff is closed--but but it is open. What the ---?.
jetrod is offline   Reply With Quote
Old 06-27-2011, 11:23 AM   #2
BrianBurkert
BrianBurkert's Avatar
Default Re: Fuel problem- When restarting hot motor
Sometimes in extreme heat, the 10% ethanol fuel boils in the carburetor, causing a vapor lock of sorts. Try turning off the gas valve before you shut the engine down. Let the car run out of gas. When you restart, open the fuel valve and cool, fresh gas should cool the carb down enough to avoid the boiling.
The long term fix is to add some Mystery oil or diesel fuel to the gas/gasohol to raise the boiling point.
If the problem persists, also check for blockage in the fuel line and make sure your fuel cap is venting properly.
BrianBurkert is offline   Reply With Quote
Old 06-27-2011, 02:21 PM   #3
marc hildebrant
marc hildebrant's Avatar
I had a similar problem in Colorado when the air temp was in the upper 90's (most summer days). The problem is vapor lock caused by the fuel boiling in the carb.
Marc
marc hildebrant is offline   Reply With Quote
Old 06-27-2011, 02:29 PM   #4
MrTube
MrTube's Avatar
I have heard of people adding multiple paper gaskets between the carb and intake manifold to insulate it some. Not sure how well it works?
MrTube is offline   Reply With Quote
Old 06-27-2011, 02:43 PM   #5
dmaxweb
dmaxweb's Avatar
Has anyone used a phenolic spacer?
dmaxweb is offline   Reply With Quote
Old 06-27-2011, 04:56 PM   #6
ford1
i have and they work xlnt especially if your using an aluminum manifold, use at least a half inch phynolic bock, also plug the heat cross over passage in the manifold, it runs right behind the carb thru the intake manifold, its used as a heater to warn the carb ib cild weather, but with a flathead its not needed, plug with copper pennies, they fit perfect, dont use the new alloy pennies they will just be eat up by the exhaust gasses
ford1 is offline   Reply With Quote
Old 06-27-2011, 05:37 PM   #7
John Duden
John Duden's Avatar
is there any cork in the shut off valve?
John Duden is offline   Reply With Quote
Old 06-27-2011, 06:20 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Where is the heat crossover that should be plugged???
Old 06-27-2011, 06:31 PM   #9
Benson
Benson's Avatar
Have you tried gas with no ethanol or lower % of ethanol ?
Any chance you have some winter gas left over from Michigan?
NC has a bunch of stations! Click the "details" tab on right side, not all grades are ethanol free.
http://pure-gas.org/index.jsp?stateprov=NC
Benson is offline   Reply With Quote
Old 06-27-2011, 06:36 PM   #10
Russ/40
Russ/40's Avatar
He spends a lot of time on the V8 forum. He's confused as to where he is.
Russ/40 is offline   Reply With Quote
Old 06-27-2011, 06:36 PM   #11
Robert
BrianBurkert is right on the money. Add a little MMO, ATF, maybe even castor oil (which is my favorite-smells good when it burns) to your gas tank at each fillup. Not only will adding a little oil raise the boiling point of your gasoline to help prevent the dreaded vapor lock, it will also help to lube the top side of your engine. Good luck!!
Robert is offline   Reply With Quote
Old 06-27-2011, 06:59 PM   #12
ford1
LOL opps, your right, a senior moment, brain fade, low caffene content, im going back to the v/8 room, lol god what a blunder
