12-20-2020, 12:00 PM | #1 |
59a heads on an 8ba block?
What does it take to use 59a Edelbrock heads on a late block? What modifications? Gaskets? etc.
12-20-2020, 12:08 PM | #2 |
Re: 59a heads on an 8ba block?
Hello. I believe the water transfer holes at the front of the deck face need blocking off and that is it. I would also think the 59 type gaskets will be best as they follow the shape of the head.
Never done it myself, that's just what I think you have to do. Mart. |
12-20-2020, 12:15 PM | #3 |
I have done it a couple times with no problems. Used 59 AB gaskets and plugged a couple small holes in the 8BA block and everything worked fine.
12-20-2020, 02:24 PM | #4 |
Forgot, I got my information from the book How To Build A Flathead by Frank Oddo.
12-20-2020, 02:49 PM | #5 |
Longer head studs?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-20-2020, 03:38 PM | #6 |
https://www.jalopyjournal.com/forum/...athead.378965/ Be sure that whatever you use to plug the holes is flush with the top of the block. |
12-20-2020, 03:48 PM | #7 |
Works just fine, I never use studs, pain in the but. Torque to 45 ft lbs thru 3 heat cycles, or till you don't feel any more movement. Also use hardened washers under the bolts, or nuts.
Gramps |
