06-17-2022, 01:21 PM | #1 |
SBF tri-power woes - smoking like a chimney
I've installed a vintage Ford performance tri-power set-up (Buddy Bar manifold) on my 347 sbf. The Holley carbs (dated 1964) are List 2436 (primary) and 2868 (Secondaries). Prior to install I cleaned, re-surfaced to flatten warpage, centered the throttle plates, replaced everything, and generally rebuilt.
Synching the linkage and fabbing an accelerator linkage took some fiddling, but it's now done and correct. The engine starts, runs, and idles well and sounds amazing, but upon warm-up it begins to push clouds of blue/white smoke out the exhaust. It never did that with the former Holley 4160, so I don't think the rings or valve seals suddenly went south; the pvc is fine. All I can figure is that the carbs are dumping fuel into the manifold, since it looks too wet when I peek down the barrels (accounting for the shot by the accelerator pumps). I've even lowered the fuel bowl floats to eliminate the common problem of flooding from overfilled bowls. I cannot see or find any leaks, inside or outside. In addition, I cannot find any leakage on the bench with carbs hooked up to a fuel pump. I do have a sneaking suspicion that these carbs might be simply worn out (although spraying starting fluid around them I can't find vacuum leaks, even at the throttle shafts). By the way, initial timing is 15 degrees BTDC, oil is fresh, and pump gas is 93 octane. Any ideas what's going on and steps to take to sort this out? |
06-17-2022, 03:36 PM | #2 |
Re: SBF tri-power woes - smoking like a chimney
Since it doesn't heppen until the engine warms up, do you think the "white" smoke might be steam from a blown head gasket? Sometimes a blown head gasket can allow water into the cylinder causing steam to come out of the exhaust. Just an idea.
06-17-2022, 04:28 PM | #3 |
yeah, but the smoke is pretty oily smelling, and it's spewing equal out of both exhausts, so I don't think it's coolant from a blown head gasket.
06-17-2022, 04:50 PM | #4 |
I'm not suggesting that it is a head gasket issue, but keep in mind that if your exhaust has an X-pipe or crossover, the exhaust from one side can migrate to the opposite side. And a blown head gasket is usually more noticable on acceleration.
06-17-2022, 06:16 PM | #5 | |
Do you have a vacuum gauge?
With the carbs apart, did you record jet sizes, power valve sizes, metering block ID, etc? The previous owner may have jacked them up. EDIT - Quote:
Again, can you give the FORD CASTING ID/DATECODE Nos if still there?
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 06-17-2022 at 08:16 PM. Reason: The Usual |
06-17-2022, 06:47 PM | #6 | |
ACCEL LINKAGE KITS WERE AVAILABLE 1963 FALCON - C3DZ 9B843-A
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
06-18-2022, 09:38 AM | #7 | |
06-18-2022, 09:43 AM | #8 |
Final post (I think).
The issue is that when setting up and tuning the carbs I dumped a ton of gas into the manifold that, of course, made its way into the crankcase, thereby diluting the oil. The exhaust system thereby got a good internal coating and dose of diluted oil. New oil and filter is on, and the carbs tuned properly; no more gas leaks. The engine runs perfectly, now. However, I've got a few miles to go before I burn all the diluted fuel out of the exhaust system, and that's the root source of the stinky smoke I'm emitting. No smoke till the engine warms up, and as the exhaust system gets hot, it begins to blow smoke like a smoke bomb. Let it cool off, and there's no smoke till the exhaust heats up again. That's it. |
06-18-2022, 10:29 AM | #9 | |
!!! GOOD DIAGNOSIS !!! I was going to suggest once running correctly to pull the dipstick and give it the sniff test. The same principle applies to late models that have O2 SENSORS on them. Diluted oil throws everything off.
06-18-2022, 06:49 PM | #10 |
Where is the vacuum source for your PCV?
06-19-2022, 01:18 PM | #11 |
Try to PM the original poster and ask. He must not get here often. Of course, let the rest of us know also ...
EDIT - 20 JUN 2022 I sent a PM to the OP. Hopefully he will see it and get back as I am wondering also ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 06-20-2022 at 08:18 AM. Reason: THE USUAL |
06-19-2022, 07:00 PM | #12 |
Water from some place. Bet the radiator is dropping a little.
06-19-2022, 07:03 PM | #13 |
I put a tri-power on my 57, and really kinda like it.
