Old 06-26-2022, 08:04 AM   #1
metro1
Default Plugged holes in floor
While replacing some flooring in my '59 Galaxie I noticed there is a hole with a rubber plug on each front pan. What are they for? You only see the top of the frame when you look through. Any reason I need to add the hole to the new floor.
metro1 is offline   Reply With Quote
Old 06-26-2022, 05:16 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Plugged holes in floor
Below is a photo of a 54 floor board. If the holes are at the forward tunnel, they allow you to remove the top convertor housing bolts to R&R the AT -
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 06-26-2022, 05:30 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
Default Re: Plugged holes in floor
'55 and later Ford cars had large rubber plugs on the flat part of the floor (one on each floor pan, for a total of four, two in front and two in back). Earlier models may have had floor plugs also. These were provided for water drainage, but you had to lift up the floorcovering to access them.
Would have been useful for convertible models left out in the rain with the top down, but i doubt anybody bothered popping the plugs to drain the water regardless of sedan, hardtop or convertible.
Notice that the repro floorpans you get do not have the drain holes stamped out, nor any body mounting bolt holes. When I put my new floorpans in, I did not bother to punch out drain-holes.
Old 06-26-2022, 06:25 PM   #4
metro1
I thought they might be for drainage but like you said who is going to remove the pad and carpet to do so. Kind of a weird idea.
Old 06-26-2022, 07:40 PM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: Plugged holes in floor
They may be for access to things like body mounts, trans service, etc. Make sure you check around the openings.
- WHY IS IT ... -
