06-19-2022, 04:54 AM | #21 |
Re: Rear Brake Shoes
LOOK HERE - https://www.summitracing.com/parts/AGB-55PG#overview
Your brake size is 11 X 1 3/4 correct? Don't toss the old shoes if they are original FORD as most new replacement do not use the OEM table. The nice part of having them relined is that they can arc grind the shoes to match your drums if you give them the drum mic specs. I see where RAYBESTOS has been obtained by another 'WORLD MANUFACTURER' so be advised.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
