05-07-2022, 01:21 PM | #1 |
flathead in a model a frame
can you install a flathead in a model a frame either a v860 or a 59ab and is there a kit to do it
05-07-2022, 03:42 PM | #2 |
Re: flathead in a model a frame
05-07-2022, 04:36 PM | #3 |
Mike Bishop and Vern Tardel's book on building a traditional Ford hot rod covers the old ways of solving the problems of the full size flathead V8. I wouldn't think too much about a V8 60 since they just don't really have the power to do much. I'd use a built banger before using a little V8 myself.
05-07-2022, 08:48 PM | #4 |
Rotor Wrench has a good point. With a little work and some speed parts the Model A engine can put out 90 horsepower. A little more work and more speed parts and it can put out more. See https://www.modelaparts.net/dynoshee...ynosheets.html. With the availability of the Burtz engine there is really no reason to go to a V8 unless you are looking for the cool factor.
05-07-2022, 09:36 PM | #5 |
I watched this video a while ago. Installing a Flathead V8 in a Model A pickup with a bolt-in kit.
https://youtu.be/QBUrzt9PUQg
"whatever works!" |
05-08-2022, 03:58 AM | #6 |
Tonight I saw an 8ba in an 8N tractor. It had Offy heads and manifold and they said it made just over 100 hp. |
05-08-2022, 08:36 AM | #7 |
The Funk brothers designed a lot of things back in the day. The Funk airplane is kind of a rarity now days. The Ford tractor conversions did a lot better with both H series 6-cylinder and flathead V8 conversions being produced. Folks are coming up with similar tractor conversions in the modern era.
After watching the You-Tube on the easy bolt in, I came to two conclusions about that. 1. It's not an easy install as was advertized. The fit needed a lot of tweeking for a "bolt in" and the tweek on the front cross member took away some of the strength there. 2. It does almost nothing to reinforce an already weak frame design. The use of the 1932 K-member at least added some reinforcement to the frame as long as the legs are used on both sides. Just bolting the rear engine mount to the center cross member makes for a problematic structure. The model A engine and flywheel cover added some strength to the frame by tying into it. All that is lost when deleting that type of structural reinforcement. Even an F1 cross member or a fabricated one would be better than deleting it altogether. |
05-08-2022, 12:29 PM | #8 |
The V8 60 is a lot less cubic inches (136) than the original Model A engine (200) and I don't think you will be happy with the result. Drive one first.
Charlie Stephens |
05-08-2022, 03:20 PM | #9 |
59ab
"I can't cry as long as I know the Lord has risen " |
05-08-2022, 03:49 PM | #10 |
The "A-V8" is a very popular build for hot rods and speedsters alike, it certainly can be done. I have the 1952 edition of the Ford Speed Manual which is a good read for ideas.
Model A's never die, they are just missing in action. |
05-08-2022, 03:56 PM | #11 |
Who needs a V8?
05-09-2022, 01:43 AM | #12 | |
05-10-2022, 07:55 AM | #13 |
If that is street legal, you guys get away with anything. That would never pass engineering inspection (required before registration) with cross members cut and so much power to say nothing of brakes, seat belts, collapsible steering column etc etc. but we live in different legal jurisdictions.
sounds like your hands are tied Synchro many states here you can do pretty much as you please. Heck, if a modern car here in NJ has a broken frame, but it passes pollution control- you are handed a clean bill of health! crazy but true. |
05-10-2022, 08:01 AM | #14 |
https://www.verntardel.com/store/p28...Winner%21.html
Get this book. Best guide out there to walk you through what you want to do. |
05-10-2022, 09:14 AM | #15 |
I try to stay out of anything political but I'm sure most folks would agree that free countries aren't always as free as we would like them to be. That's all I have to say about that.
On the bright side, it helps to keep things pretty stock when some changes aren't allowed. This is OK for the purist restorer. The hot rodder, not so much. |
05-11-2022, 08:31 AM | #16 | |
Terry |
05-11-2022, 09:12 AM | #17 |
So much power? A flat head V8?
A modified flathead A or B engine develops almost the same hp and torque.. with a much quicker torque rise.. the time and money you spend on a V8 sure is a let down the first time you drive it.. not to mention it’s crack prone and you fight overheating issue..but hey, it sounds sexy.. Looks like not everything is better in OZ.. |
05-11-2022, 10:04 AM | #18 | |
Now, if we are talking OHV conversion to said banger, know you've got my attention. Different strokes for different folks.... |
05-11-2022, 10:42 AM | #19 |
No doubt Tim modified to modified..hopping up a banger is Walmart, a V8 is Nordstrom. Wallet accordingly..
05-11-2022, 10:48 AM | #20 | |
That said, no modified flathead is cheap to build. Do it right once. To your point though, more power, more problems or things that need to be changed to handle the power. |
