09-23-2011, 07:07 PM | #1 |
Strange Crankshaft
I just bought what appears to be a 49-53 Merc crankshaft (large holes in rod journals). It appears to be serviceable with a regrind. However, the front pulley shaft has been partly turned to a smaller diameter. See attached picture.
There appears to be enough metal to support the gear and pulley. However, I cannot figure out why someone would turn the middle of the pulley shaft. You can't get a sleeve on it and there is nothing to center the slinger. Any one seen one like this? Any ideas on why it would have been machined this way? Gary |
09-23-2011, 07:57 PM | #2 |
Re: Strange Crankshaft
Is it possible that modification is what's left of a marine front drive? ..B.
09-24-2011, 08:38 AM | #3 |
Or an industrial pump application?
Building a 29 Sedan on 32 chassis........ very slowly.... |
09-24-2011, 09:55 AM | #4 |
Or, an area which has been worn as a result of many rotations of a slipping drive hub.
09-24-2011, 02:12 PM | #5 |
Or maybe it was metal sprayed originally to repair and the spray material came off.
09-24-2011, 02:57 PM | #6 |
09-24-2011, 06:13 PM | #7 |
Is it possible that the piece is screwed in to the end of the crank?
09-24-2011, 06:57 PM | #8 |
Why not machine the rest and then a simple one peice sleeve? Have a great day Gary
09-24-2011, 08:18 PM | #9 |
What is the diameter of small area? I think the normal crank snout is a little over 1.3 inches.
09-25-2011, 09:28 AM | #10 |
Just thought of an easier way to fix that. Make a key way in the shaft, make a key the stock height, make a split collar that fits in the shallow area, use stock seal sleeve, use stock pulley pulley.
