01-31-2014, 12:33 AM | #1 |
1930 side mount spare tire mount
Hi,
Can anyone furnish a picture or tell me exactly how the base of the mounting bracket mounts on the frame. I'm installing a LH fender side mount on a 1930 Model A. Thank you in advance, Mike |
01-31-2014, 05:39 AM | #2 |
Re: 1930 side mount spare tire mount
hello mike
i put one on my 1930 tudor on the frame there are dimples in the frame to drill the holes so it is pre marked when i get home from work i will take a photo for you real simple to do you may have to remove paint to find them kevin 1930 model a tudor 1923 model t roadster p/u |
02-12-2017, 05:04 PM | #3 |
Trying to reattach spare side mount on 28 tudor. New splash shield have installed; no
previous holes to go by. Need help and/or pictures. |
02-13-2017, 11:48 AM | #4 |
Try this on for size.
It doesn't look legible, so here's where it came from: http://www.jalopyjournal.com/forum/t...ensions.44349/
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 02-13-2017 at 12:45 PM. Reason: Added info |
02-13-2017, 12:54 PM | #5 |
My friend wanted twin side mounts when we restored his pickup. I mounted the splash aprons then used a pencil through the frame mount to scribe the largest circle the pencil would make, then I found the center of the circle and drilled the hole. They came out perfect. I used a hole saw on slow speed.
02-13-2017, 06:32 PM | #6 |
Paul in CT |
