09-28-2013, 02:05 PM | #1 |
Faulty Brake light switch
Yesterday, I go to crank the A. After 6-7 turns, it has not fired yet. I check and I have a blown fuse. I replace the fuse and immediately, it burns out again. Today, I isolate the problem down to the brake light switch. I suspect that I put a reproduction switch on the car in the 90s but could not swear to that. Is my only option for eliminating brake light switch woes to replace with an original. I have read that A&L has a good 30-31 but not the one that mounts on the side of the transmission. What are my options?
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
09-28-2013, 03:06 PM | #2 |
Re: Faulty Brake light switch
Try doing a search, I believe Tom Endy did a thread on how to ck, disassemble, adj, and lube=as good as new.
Paul in CT |
09-28-2013, 05:26 PM | #3 |
I just had a similar problem and replaced it with another repro...complete junk! After some research through the old post I found A&L parts who kakes an exact reproduction of the original a little pricey, $40, but completely worth it as it took no adjusting or extra work to eliminate my
09-28-2013, 06:07 PM | #4 |
The tranny mounted switch is easy to fix. See my pictures in reply #4
http://www.fordbarn.com/forum/showth...itch+wesenberg |
09-28-2013, 06:49 PM | #5 |
Thanks Guys. I'll pull it apart the first of the week.
09-28-2013, 06:56 PM | #6 |
11-25-2013, 02:47 PM | #7 |
I was having a problem with my 31 pickup brake light switch. I took the advice from one of the posts with a slight twist. Mine is the cross member type switch. I threaded the shaft of the switch with a 10-24 thread then I put a lock nut with a nylon insert flush with the end of the shaft. Then I slightly enlarged the hole in the cross member where the shaft goes through to ensure good clearance. The nut gives a much bigger mating surface for the plunger.
Problem solved Last edited by Stew; 11-25-2013 at 04:17 PM. |
