Old 06-11-2021, 09:33 PM   #1
CrownVic55
CrownVic55's Avatar
Default T85/r11
Does anyone know the weight of the T85/R11 transmission? Going to install one in 55 Crown. My Son has a lift so getting it up is no problem but lifting it may be.
Thanks
Ben
CrownVic55 is offline   Reply With Quote
Old 06-12-2021, 03:10 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: T85/r11
Ford application T-85s w/ od that I have weighed come in at 149 lbs. (!)
SOURCE - http://forums.y-blocksforever.com/To...px?PageIndex=2
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 06-12-2021, 11:55 AM   #3
dmsfrr
dmsfrr's Avatar
Default Re: T85/r11
I think they're getting heavier as the years go by.
Had to use a small engine hoist to get one in and out of the back of my truck.
Old 06-12-2021, 12:11 PM   #4
CrownVic55
CrownVic55's Avatar
Default Re: T85/r11
Kultulz-thanks for the weight info. And dmsfrr, I hear you on them getting heavier as the years go by. I even went to a smaller sized coffee cup to keep weight down.
Ben
Old 06-12-2021, 05:32 PM   #5
KULTULZ
KULTULZ's Avatar
Thumbs up Re: T85/r11
Also think decaf, no sweeteners and no latte' ...
And just a touch of JD ...
- WHY IS IT ... -
Old 06-12-2021, 07:04 PM   #6
rotorwrench
rotorwrench's Avatar
Default Re: T85/r11
The T85 R11 is the heavy duty 3-speed & OD. They are relatively heavy for a car & light truck transmission but they can take more torque and especially if it is the R11N with the nodular housing. These will hold up to a 390 FE in an F100 pickup truck.
Old 06-13-2021, 12:00 AM   #7
miker98038
miker98038's Avatar
Default Re: T85/r11
Well that explains why as the 125lb weakling I need help from my 190lb friend to wrestle the T85 O/D into my 55 bird. Worse when it went in for real with the engine attached.
Wasn’t that used behind the early 406’s before the 4 speed come out? Or is my memory playing tricks? They are a tough unit.
miker98038 is offline   Reply With Quote
Old 06-13-2021, 12:02 PM   #8
rotorwrench
Default Re: T85/r11
The T10 was based on the T85 3-speed but there are variations of the T-10 as well and some are better than others for performance. If a person wants a higher speed overall than a 1:1 drive will give then the overdrive is the best choice. I would take it easy on anything less than a 31-spline top loader. TKO-600 is an option but there are other things to know about the shifting to 3rd and just plain shifting a lot more than a 4-speed. With the T85 R11 and a rear axle that's not too tall, a person can start out in 2nd and only shift once to 3rd. A lot less shifting going on there with the shift to OD being automatic.
I would want a stronger 4-speed or more speeds behind a real healthy large FE engine. The super T10 wasn't bad but it's still only a 1:1 drive in high gear.
Old 06-18-2021, 04:31 PM   #9
KULTULZ
KULTULZ's Avatar
Post Re: T85/r11
Here is some more info on the TRANS some might find useful -
http://ford-mel-engine.com/viewtopic.php?t=1483
- WHY IS IT ... -
Old 06-27-2021, 01:43 PM   #10
Brushwolf
Default Re: T85/r11
Good link. I have a soft spot for the R11 T85..
Brushwolf is offline   Reply With Quote
