Old 03-15-2015, 08:31 PM   #1
dudley
Default need 30-31 roadster measurement
Could someone get me the distance from the top of the quarter panel where it bolts to the panel above the trunk lid down to the top of the sub rail at the rear of the cockpit? Thanks ahead of time.
dudley is offline   Reply With Quote
Old 03-17-2015, 03:53 PM   #2
Lanny
Lanny's Avatar
Default Re: need 30-31 roadster measurement
Sorry, I don't have an answer for you, but someone here should be able to help you.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 03-17-2015, 04:25 PM   #3
MAG
MAG's Avatar
Best I can tell...26" from top of belting to bottom of quarter.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 03-18-2015, 04:01 PM   #4
dudley
Thanks MAG , but the measurement I need is inside, behind the seat where the quarter meets the center panel in front of the deck lid. it should be somewhere between 23 3/4 and 25 inches. I am installing the rain gutter to wheel well supports and I can move that flange up and down about 1 1/2 inches. this is the flange that the tack rail set on. Right now i have the distance from the flange down to the top of the sub rail at 24 1/4 but I would like to be sure before I drill holes and rivet the support in. That front support is what holds that distance.
Old 03-18-2015, 09:20 PM   #5
62pan
I read your post three times and I am still not sure what you need. Does this photo show the part where you need the measurement?
62pan is offline   Reply With Quote
Old 03-19-2015, 01:50 PM   #6
dudley
Sorry for the confusion I will try to post pictures. Ineed the distance from the arrow straight down to the top of the sub rail.
Old 03-19-2015, 02:44 PM   #7
MAG
MAG's Avatar
dudley. I can't get to that exact area where the arrow is pointing. Upholstery inner panel is in the way. But I measure 24" from the bottom edge of the flange (torn area pic. 3) (approxomately 2 " rearward from the hole to left of arrow) to the sub rail.
Hopefully you can project where you need to be from there.
Old 03-19-2015, 03:11 PM   #8
62pan
Best I can do is 24 3/4 inches from your arrow to the top of the subrail.
