07-24-2011, 06:13 PM | #1 |
8BA fuel pump rod stroke?
Can anyone give me the stroke of the rod??? I think the length is 10-1/8 inches, but I need to know the stroke length. Having a problem with the pump not delievering the fuel out of the pump..........
07-24-2011, 06:28 PM | #2 |
Re: 8BA fuel pump rod stroke?
.200-.250 is in the ball park. ken ct.
07-24-2011, 06:30 PM | #3 |
Check and make sure the rubber diaphragm inside the pump doesn't have a small pin hole in it. Also check to make sure gas is not going into your oil pan.
07-24-2011, 06:57 PM | #4 |
Ford 8BA shop manual shows .185 min .200 max.
07-24-2011, 07:12 PM | #5 |
If it is a stroke issue, it's not likely that your rod stroke has changed. More likely your full stroke isn't being translated to the diaphram. This can happen in two ways: The rocker arm pivot point is wallowed out, or your pumpstand gasket is too thick.
Alan |
07-24-2011, 08:34 PM | #6 |
07-25-2011, 09:58 AM | #7 |
Thanks to the replies on the stroke length......I measured mine the best measurement I got was right at .200 plus or minus a few thousands. So the cam is ok. New pump on order at NAPA. I am getting a new rod also
mine has been welded on and looks like a beaver has been chewing on it the top end! |
07-25-2011, 10:10 AM | #8 |
Good luck with your NAPA pump from China. ken ct.
07-25-2011, 06:26 PM | #9 |
I just solved a fuel pump problem with my 8BA. If you do a search of threads on this site "8BA fuel pump" you will get several threads that address different problems. I have a dual action fuel pump on my 8BA and it works fine except after 20-30 minutes it starts to stall or hesitate, like a vapor lock. I kick in my electric and let it pump for a minute or two and everything is fime for 20-30 minutes. My pump was recently rebuilt so I was pretty sure that wasn't my problem. I took the push rod out and it measured a touch over 10 inches. The correct length is 10 1/16 inches. Look all over for a new rod and couldn't find one. Went to East Texas Fasteners and got a 7/16 water harden rod and made my own push rod. To allow for wear, I made my rod 10 1/8 inches because you have wear on both the cam end and the pump end. I used liquid gasket for the pump to engine to make sure I had enough lift. I think .200 is about right. Anyway have taken a couple 15 mile drives and no more hesitation. It was a hot day (Tyler, Texas has had 26 days of 3 digit temps and most likely the entire month of July will be in the triple digits) and it worked fine. Good luck, JBD
07-25-2011, 06:46 PM | #10 |
I have the correct rods for the 8BA. ken ct PM or email [email protected].
