Old 06-16-2015, 11:06 AM   #1
JT FORD
JT FORD's Avatar
Smile Out come to Radiator Leaking
Shop ordered a new radiator core. Brass and copper like original.
Removing and using my tanks, brts, etc. Sandblasting the parts and painting them. Resoldering the inlets and outlets. Cost $ 500.
About a week to get the core, should be like new. An aluminum radiator was $725.
JT FORD is offline   Reply With Quote
Old 06-16-2015, 12:14 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Out come to Radiator Leaking
JT, Good choice to go for a recore, and not just for a cost savings either.
A caution on the paint if it's not too late: The cooling fins and tubes should have the least amount of paint possible to minimize the insulating properties of paint.
Alan
Old 06-16-2015, 12:22 PM   #3
WestCoast
radiators cool just as well with out the paint, just not as pretty, the paint is there to prevent some corrosion on the fins and tubes ,and it does dress up the radiator
WestCoast is offline   Reply With Quote
Old 06-16-2015, 03:44 PM   #4
B-O-B
B-O-B's Avatar
Many moons ago I worked for a paint outfit. We sold OEM only in 5 gal pails & drums. We sold radiator black to radiator mfgs that was so thin you could see daylight thru it when you poured it. All they wanted was to make the radiator look black.
B-O-B is offline   Reply With Quote
Old 06-17-2015, 08:45 AM   #5
Johnnydidd
Johnnydidd's Avatar
Will aluminum cool better than copper
Johnnydidd is offline   Reply With Quote
Old 06-17-2015, 11:02 AM   #6
ford38v8
ford38v8's Avatar
No. Aluminum will pass the heat less effectively than copper. The best would be gold, but...
Alan
Old 06-17-2015, 12:22 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Actually, silver is the best thermal conductive metal at 406 w/km. Then, pure copper at 385, gold at 314, pure aluminum at 205, and brass at 109. SILVER is also the best electrical conductor. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-17-2015, 01:14 PM   #8
ford38v8
ford38v8's Avatar
That all goes to demonstrate that one should not always believe what one thinks!
Alan
Old 06-18-2015, 12:18 AM   #9
brigrat
brigrat's Avatar
A word of caution, doing a recore is fine as long as you remember your top and bottom tanks are the weak points as they were stamped way back when, have expanded & contracted by years of heating and cooling. They have the potential to develop fine stress cracks, use the lowest pressure radiator cap you can get away with. JMO!
brigrat is offline   Reply With Quote
