Old 11-21-2011, 03:03 PM   #1
hardtimes
hardtimes's Avatar
Default throttle linkage Q..
Evidently, a lot of Model A owners utilize downdraft carbs. I'm asking questions regarding your linkage design/fabrication setup, because I'm always looking for improvements. Is there any source that fabs/sells such custom/professional linkage..or are you on your own in this endeavor? The stock model a linkage just is not designed for downdraft. Pictures of your successful fabrication would be great to share.
Old 11-21-2011, 04:05 PM   #2
CarlG
CarlG's Avatar
Default Re: throttle linkage Q..
The linkage for my Weber downdraft came with the "kit" -- Carb, Filter, Manifold & Linkage. Plug & Play!
Old 11-21-2011, 04:13 PM   #3
Charlie Stephens
There is a lever that mounts to a threaded boss on many manifolds. You could fabricate one but a cast one that looks good used to be carried by Sacramento Ford Parts, vintageford.com.
Charlie Stephens
Old 11-21-2011, 04:58 PM   #4
miss victoria
linkage and manifolds on ebay go to model a ford weber carb manifold / linkage. item#280774211472 and 280774211001
miss victoria is offline   Reply With Quote
Old 11-21-2011, 10:22 PM   #5
hardtimes
hardtimes's Avatar
Charlie Stephens
I'll check out these leads.
Also wondering if anyone has tried to use or thot about using a '32 four cylinder 'cowl' mounted 'spoon' pedal setup. It is long and brings the actuating arm fully across the cowl to an area parallel to the downdraft carb throttle actuating arm?
Old 11-22-2011, 10:42 PM   #6
Charlie Stephens
What are you trying to accomplish? The throttle assembly where it attaches to the rod going to the carburetor ends up in the same place on a Model A and Model B. What are you working on? If it's an A or B just use the pedal assembly designed for the car. Post if it is something else like a home built speedster.
Charlie Stephens
Old 11-24-2011, 12:12 AM   #7
hardtimes
hardtimes's Avatar
Charlie Stephens
Charlie,
I am working at getting "full" pedal and easily on the assembly that is pictured.
Presently, with floor mat/backing and original foot pedal linkage, I'm getting about half throttle. As pics show the linkage, as configured, does not have sufficient travel with foot pedal to flr mat ...for other end to open carbs fully. In other words there is insufficient travel of (pictured) right end of (STOCK) throttle linkage. Bending won't help anything. I think that it's a matter of leverage...that is , end of stock link is too short
And, this setup is not parallel, but downward pointed. Whereas, I think that the '32 that can be mounted on cowl (as on '32) can eliminate the intake mounted manifold lever (bellcrank) and be connected , via rod directly to carb.
Make any sense and or suggestions from what you see??
Old 11-24-2011, 01:14 AM   #8
Geo. H
You're probably going to have to custom make what you need. Problems I see are too low of a pivot on your manifold, and exhaust header interference. I don't see where the 32 pedal would help.
Geo. H is offline   Reply With Quote
Old 11-24-2011, 10:12 AM   #9
1931 flamingo
1931 flamingo's Avatar
What if you put the top of your verticle arm on the bottom?? Or make a new verticle arm altogether??
Paul in CT
Old 11-24-2011, 02:38 PM   #10
hardtimes
hardtimes's Avatar
No header interference...that is, appears closer in pic than is.
Pivot point is valid question ! thanks...Yeah, custom mabe it,eh?
Old 11-24-2011, 02:42 PM   #11
hardtimes
hardtimes's Avatar
Paul in CT
Good ideas , thanks !
Hmm, where's that fab guy (bchoppit??) mabe he has some fab input
Anyway, happy turkey day to all youse fordbarners and family today !!
Old 11-24-2011, 03:08 PM   #12
V4F
V4F's Avatar
the stock foot pedal wants to push & the carb wants to be pulled . the bell crank changes the pedal motion to a pull . build a flat aluminum lever ( 1x1/8") & attache it to the manifold , but leave a space so it will move freely . make it about 10" long & drill holes for the pivot & linkage to bolt to . drill the pivot hole about 4" from the bottom , then drill one hole at the bottom & top . use the linkage ends that snap over a ball (like on your stock pedal) .
i had to bend the linkage to get around my header on the bottom . also i bent the top (above the pivot hole) to match up with the carb . depending on how far your pedal will push the bell crank will determine the length of the rods ......... clear as mud ? .. steve
V4f
V4F is offline   Reply With Quote
Old 11-24-2011, 11:22 PM   #13
hardtimes
hardtimes's Avatar
Thanks Steve! I got your pics and will study your creation !
Old 11-25-2011, 01:33 PM   #14
model.A.keith
Work in (slow) porgress..........the aim is to get the 'bell crank' vertical.....and shorten the control rods to length, using a threaded bar set in the middle of each rod........as i said slow progress at the moment.
keith
model.A.keith is offline   Reply With Quote
Old 11-25-2011, 02:25 PM   #15
2935ford
2935ford's Avatar
Here is a system I used on a single downdraft. It was an Ansen intake w/header all from Red's Headers. He still carries them.
Worked very well.
2935ford is offline   Reply With Quote
Old 11-25-2011, 02:33 PM   #16
2935ford
2935ford's Avatar
Here is the same car different motor dual downdraft setup (similar to yours).......still using the stock pedal arm.
Also looks like you need to turn your arm so the two holes are at the bottom.
Old 11-25-2011, 04:21 PM   #17
hardtimes
hardtimes's Avatar
2935 ford,
Your second pic is a bit blurry to my ole eyes, but it kinda confirms what an early conclusion ...that I've come to, that is- that the SLANTED LINKAGE in your first pic , in my pic and in several other pics that guys have sent me is WRONG ! You are correct, I believe, that my bellcrank is not correctly positioned. BUT this bellcrank is NOT going to correct the problem like your SECOND pic linkage has corrected it! Your improvised bellcrank shows horizontal/parallel linkage and more correct use of mechanical leverage...thanks for your ideas/input
Anyone got something better...please show is a pic
Old 09-12-2020, 11:58 AM   #18
Nosetime
Nosetime's Avatar
with Stromberg Bullet ends, thread your own custom length rod. Secrets of Speed has a diagram on building an easy linkage
File Type: jpg 07B87EDE-9820-4583-A877-43FCE6AEC810.jpg (73.8 KB, 54 views)
Nosetime is offline   Reply With Quote
Old 09-12-2020, 05:12 PM   #19
john in illinois
john in illinois's Avatar
I just fabbed up a flat arm and put different spaced holes on each end. It is just a ratio you are looking for.
John
File Type: jpg 867CC079-3653-4C0F-9D39-EFFE3710F443.jpg (59.5 KB, 36 views)
Welcome each day
john in illinois is offline   Reply With Quote
