Old 06-13-2015, 02:20 PM   #1
JT FORD
JT FORD's Avatar
Default Need a Radiator for l949 Ford Car
Mine sprung a lead just below the top tank in the center of it. It has been reworked before and maybe it can not be fixed. If not I need a new one. I looked in Carpenter, Speedway and Mac's catalogs and they
don't list one.....Someone must sell them?
JT FORD is offline   Reply With Quote
Old 06-13-2015, 02:59 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: Need a Radiator for l949 Ford Car
I have no experience with this company, but I hear them mentioned on the forums.
http://www.thebrassworks.net/shop/Re...c86a9e71990fac
-Jeff H
Old 06-13-2015, 05:46 PM   #3
Ronnie
Ronnie's Avatar
Have it re cored
R
Ronnie is offline   Reply With Quote
Old 06-13-2015, 07:01 PM   #4
TJ
TJ's Avatar
Go to the website of US Radiator. They have them in copper/brass and aluminum.
Old 06-13-2015, 07:37 PM   #5
tubman
tubman's Avatar
I hear there some really cheap aluminum ones on eBay. Probably not the best, but if you're in a budget bind, the may be a way to go. (A friend of mine let the jack down prematurely on his 2009 BMW 328 and wrecked his radiator. An aftermarket replacement cost him $69 and seems to work just fine!)
Old 06-13-2015, 11:44 PM   #6
wga
wga's Avatar
US Radiator in Vernon, Ca. Easy to work with, excellent quality.
If your tanks are in good condition, replacing the core is easy. Stay away from those el cheapo aluminum that are off shore copies.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 06-14-2015, 08:42 AM   #7
LuckyFordGuy
LuckyFordGuy's Avatar
Try Shoebox Central They sell 49-53 ford part they are very reasonable 405-259-9222 should have one for you Rog
LuckyFordGuy is offline   Reply With Quote
Old 06-14-2015, 03:15 PM   #8
JT FORD
JT FORD's Avatar
Thanks for the replies. Monday AM I'm taking the radiator to the repair shop and see if the top tank can be removed and the tank re-soldered to the my old core.
The cores must be good because I have never had an over heating problem with this car. If that doesn't work, I will see about a new one. I see in my 2003 catalog from C & G. they were $350. Should have bought one then. I have two cars that use the same one.
