01-12-2021, 11:48 AM | #1 |
Headers For A 55 With An SBF
I’m slowly assembling the parts I’ll need to eventually swap a 302 (or at least a SBF) into my 55. I’ve been keeping my eye out for a good set of used headers; there seem to be plenty around. I’ve read here and on other sites that the 64 – 73 Mustang headers fit.
Before I actually buy I need to know which “style” of header – style meaning “shorty” or “Tri-y” or long tube etc, works best (fitment / clearance wise at least) in the mid/late 50s Fords. I’m also wondering if the “shorty” factory headers from a 90s Mustang would also work. Advantages to them, if they fit, would be availability and price – about $50 from a local wrecking yard. Has anyone used the 90s Mustang shortys on their swap? FWIW, I really do not want to modify (unless it is absolutely necessary) whichever header I get. So clearance without bending, dimpling etc is part of my goal. Thank you for your input
1955 Customline 4dr, 292 2bbl, 3sp |
01-12-2021, 01:16 PM | #2 |
Re: Headers For A 55 With An SBF
Check out Hedman 88400 headers. They fit with a 302 in a '54 but don't know about a '55.
01-12-2021, 08:21 PM | #3 |
I used a set of aftermarket shorties from an '89 Mustang on a '56. These were larger tube than the OEM units. The right side fit with no mods. I reworked one tube on the left side for better clearance by the rear upper control arm bolt
01-13-2021, 10:03 PM | #4 |
These will all fit '49-'59 Fords/302 swap without mods.....
Hedman 88400's Patriot headers Cheap chinese headers I went with the Hedman 88400's in my '54 with 5.0/AOD swap. Fit like a glove and plenty of clearance at steering box. I tried the cheap chinese headers and sent 'em back. Header flange was warped, tubes had very short weld beads (weren't completely welded) and some of the bolts wouldn't fit 'cause the tube was bent over the bolt hole! Ya get what ya pay for! Also, I wouldn't bother with the factory Mustang shorties. They weren't designed for performance, at all. The tubes are tiny to begin with and the dimples are so deep there's probably 1/2" clearance inside the tubes. |
01-14-2021, 05:39 PM | #5 | |
01-14-2021, 05:48 PM | #6 |
01-14-2021, 06:43 PM | #7 |
Good input guys thank you. FWIW, I want to go inexpensive (hence looking for used) but not cheap (so no off brand parts).
51504bat Thank you for that info Craig Do you recall the brand header you used? In the pics can see where the passenger side could get quite close. Evintho Thank you for the confirmation and pics they help me visualize the end result. Jeff great thanks on those 2 points.
01-14-2021, 11:25 PM | #8 |
I used MAC headers, but it was 15-20 years ago and they have since gone out of business
01-15-2021, 08:39 PM | #9 |
I used the Hedman headers in my 53 Courier with 302. Fit perfect until i changed to Borgeson power steering box. Then just needed a small dimple near the box. I recommend them
01-18-2021, 03:28 PM | #10 | |
