12-23-2020, 04:00 PM | #1 |
Truck rear axle with torque tube
We were give a decent looking rear axle with parallel spring mounts and obviously no provision for radius rods. But it appears to be set up for a torque tube as the pinion is 6 spline. I always thought truck pinions were tapered and keyed for the yoke and open drive shaft.
12-23-2020, 05:04 PM | #2 | |
Re: Truck rear axle with torque tube
12-23-2020, 06:02 PM | #3 |
Or...someone assembled that unit using passenger car banjo with jailbar tubes. Why??
12-23-2020, 06:12 PM | #4 |
It's just possible someone didn't quite like that transverse spring set-up. DD
12-23-2020, 06:25 PM | #5 |
Yes just had a second look i thought it was an original never opened axle but it does seem a passenger car TT head with truck tubes , why?
12-23-2020, 06:38 PM | #6 |
12-23-2020, 07:05 PM | #7 |
You should remember that the torque tube set-ups used the transverse spring. The rear articulated in an arc about the transmission/u-joint connection. The elliptical spring set-up probably does allow the rear end to move fore/aft, which is where the sliding splines at the drive shaft front yoke come into play. I believe you have a 'mongrel' (put-together) rear end there. Lots of good parts for spares there. Or, a candidate for a light trailer. DD
12-23-2020, 06:58 PM | #8 |
Is it possible somebody added the spring mounts and used it under a trailer??
12-23-2020, 07:12 PM | #9 |
Having an automotive background, I need to ask are you sure a truck banjo casing would not have the drain hole? Surely in the interest of commonality, the same banjo casing would have been used across the board???
Mart. |
12-24-2020, 03:09 PM | #10 |
Ya know Mart, I kind of jumped on that one thinking something else. You are likely correct, as I can actually think of no GOOD reason for Ford to have tooled-up a different banjo section. Merry Christmas across the pond, my friend! DD
12-24-2020, 05:00 PM | #11 |
My 38 1.5 ton has a banjo rear with a closed torque tube and parallel springs. Unsure of a drain hole it's under the cab as I am mid stride of rebuilding the trans and engine. Might be a big truck. It has steady rods on it from the rear end to the torque tube.
12-24-2020, 06:12 PM | #12 |
All the big truck rear axles I've seen look like this unless they are two speed.
