12-02-2014, 06:18 PM | #1 |
Squeaky belt
Any great ideas to stop the belt from squeaking? Belt dressing only last a short time. Thanks
12-02-2014, 06:23 PM | #2 |
Re: Squeaky belt
Change it..........
Paul in CT |
12-02-2014, 06:43 PM | #3 |
Re: Squeaky belt
A few years ago I thought that I had a fan belt squeak. I couldn't get rid of the squeak and belt dressing only made a mess under the hood. I just run tap water as a coolant and have for years. When I added a small bottle of Gunk water pump lubricant the squeak went away. Water pump lubricant also prevents rust in the cooling system .
12-02-2014, 07:05 PM | #4 |
Re: Squeaky belt
flamingo has the best and permenate cure, change belt, but if you want to try to stop the squeak your self, you will need to sand the sides of the belt to get rid of the glaze, do the same with the fan or crank pully, squeaks develop when the pullys get real shiny and the belts get hard and glazed
12-02-2014, 07:44 PM | #5 |
Re: Squeaky belt
are you running a genny or an alt
antifreeze will also make a belt squeak |
12-02-2014, 09:15 PM | #6 |
Re: Squeaky belt
12-02-2014, 09:16 PM | #7 |
Re: Squeaky belt
Im running a 12 volt genny. Thanks
12-02-2014, 09:19 PM | #8 |
Re: Squeaky belt
Spray it with 556, CRC, ETC...
12-02-2014, 09:32 PM | #9 |
Re: Squeaky belt
Bar soap against both sides of belt while the engine idles. Amazing...
12-02-2014, 09:33 PM | #10 |
Re: Squeaky belt
Not sure if this is your problem but there are many threads about running certain belts with an alt... Here is one
https://fordbarn.com/forum/showthread...ternator+noise |
12-03-2014, 08:03 AM | #11 |
Re: Squeaky belt
I had that problem and found out that the fan was rubbing on the water pump housing. Also check to be sure the fan is tight on the shaft and the key is also tight.
12-03-2014, 09:10 AM | #12 |
Re: Squeaky belt
I've had some success with a bar of soap rubbed on the belt sides. I like the idea of sanding the sides of the belt. You could also try flipping the belt around to see if it helps.
My brother had a Caravan V6 that started a belt squeal as soon as he installed a new belt. We tried everything and never could get it to stop. |
12-03-2014, 10:48 AM | #13 |
Re: Squeaky belt
I thought I had a squeaky belt once. It turned out that the front motor mount was dry. I shot some oil on the motor mount springs and my squeak went away.
12-03-2014, 01:22 PM | #14 |
Re: Squeaky belt
Some repro parts can cause the crankshaft pulley to rub the front motor mount yoke and make a hard to locate noise .
12-03-2014, 01:24 PM | #15 |
Re: Squeaky belt
If you rub soap on the belt with the engine running be carefull !!! don't forget the fan, its DANE-JUS
12-03-2014, 03:19 PM | #16 |
Re: Squeaky belt
12-03-2014, 04:59 PM | #17 |
Re: Squeaky belt
I've got to stay in practice so that I don'tforget how stuff is spelled. Bill is spoze to be back saturday.
12-03-2014, 08:47 PM | #18 |
Re: Squeaky belt
I never had a Model A belt squeek in50 years,I think I run a Gates #600 truck or bus belt,I would replace that belt.
12-03-2014, 09:51 PM | #19 |
Re: Squeaky belt
I've never had a belt squeek either. I've had other things make a noise that I thought was a squeekey belt but it always turned out to be something else.
