12-27-2021, 09:34 PM | #1 |
226 rebuild questions
Rebuilding a 226, all machine work done and ready to assemble. Two questions:
1. For the gaskets, would it be recommended to just use grease or use a sealant? This engine has lots of gaskets on the block that could be sources for leaks. 2. For the bearings, I have both NOS and new egge bearings, which one is recommended? Thanks JB |
12-27-2021, 09:57 PM | #2 |
Re: 226 rebuild questions
Some questions are easy... For me those are both tough. Egge is well known for pistons...But what could be better than NOS ford? And gaskets... grease if you think you may have to go back in. Yikes, and sealant if it's a done deal.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-27-2021, 10:10 PM | #3 |
Thanks bud, I know, we are back and forth on both. Tough call on the sealant but I think we will use the NOS bearings.
I had a third question - on the main bearing retainers. They are positioned so that the tangs for the bearings are on the same side of the block I believe but looking to confirm that. Appreciate it. JB |
12-27-2021, 10:12 PM | #4 |
226 Ford Six - 3twinridges |
12-27-2021, 10:28 PM | #5 |
Only problem I see is that with the timing cover in place, you'll not be able to see the timing marks. Yes, tang to tang
12-27-2021, 11:06 PM | #6 |
12-28-2021, 08:03 PM | #7 |
I installed the main bearings and crankshaft today. Bearing clearances are between .002 and .0015. Timing cover and pulley installed. I did take the pulley off to align the crank and cam gear. The rope seals were tough but I think we did ok. They did tighten the crank up, it takes about 25-30 lbs to turn it over.
JB |
12-28-2021, 08:21 PM | #8 |
Looks great!
I personally use sealant on the gaskets. No recommendations on the bearings from me. My guess is that they are both good. I might go with the NOS unless someone has better recommendation? Your detailed work looks great! Thanks for the pictures! Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
12-28-2021, 08:29 PM | #9 | |
I am going to use sealant on the water pump and thermostat housing. JB |
12-29-2021, 07:08 PM | #10 |
Got # 1 piston and rod in tonight. Bearing clearance looked fine at about .0015-.002. The ring gap was .007 and I didn’t file it. Spec is between .007 and .047 so I am within spec.
Still turns over fine. JB |
12-29-2021, 08:25 PM | #11 |
Assembling an engine is something I love to do. It can also be a bit stressful, or even more than a bit. Your clearances sound great and I'm a plastigauge junkie, mainly because I am often doing this with used but excellent parts. I can't say enough about how beautiful the block and new parts look contrasting with that red paint. I am really enjoying this thread about your six!
12-29-2021, 08:30 PM | #12 |
It is stressful bud. I realized after I posted my update that the one step I missed on the ring assembly was making sure I had them with top up so #1 has to come back out tomorrow. The compression rings have a top up marking. Dang!
JB |
